ogg to mp3
ogg to mp3
Postby heiowge » Mon Dec 26, 2011 11:58 pm
My mp3 player doesn't see ogg files.
Is there an easy to use program that can bulk convert 100+ ogg files at a time to mp3?
ta
Postby Rhakios » Tue Dec 27, 2011 1:45 am
It's never a particularly good idea to re-encode compressed files, but if you must then SoundConverter (or SoundKonverter for KDE users) can do the job on a file or folder basis. How long it takes will depend on how fast your computer is.
Cue someone with a way to do it from the command line...
Postby PCNetSpec » Tue Dec 27, 2011 5:26 am
cd /directory/containing/ogg/files
then
for name in *.ogg; do ffmpeg -i "$name" "$(basename "$name" .ogg).mp3"; done
ffmpeg defaults to a bitrate of 64k .. so if you want a higher bitrate (say 128k), make that:
for name in *.ogg; do ffmpeg -i "$name" -ab 128k "$(basename "$name" .ogg).mp3"; done
Linux in the UK
The Linux Community Forum
PCNetSpec
Postby nelz » Tue Dec 27, 2011 10:45 am
No need to use basename, shells can do the extension replacement themselves
"${name/.ogg/.mp3}"
which also avoids the problem of the unbalanced, nested quoted, which really need to be escaped. You also have the probem of ffmpeg losing all the ID data. Sound[CK]onverter is probably the best option.
Postby PCNetSpec » Tue Dec 27, 2011 2:42 pm
Nice :)
How about:
for name in *.ogg; do ffmpeg -i "$name" -ab 128k -map_meta_data 0:0,s0 "${name/.ogg/.mp3}"; done;
which seems to keep the metadata.
Linux in the UK
PCNetSpec
Postby nelz » Tue Dec 27, 2011 3:33 pm
That should do it, I hadn't see the map_metadata option before.
Postby Ram » Wed Dec 28, 2011 11:40 am
Think this should be moved to the Tips section...
Return to Hints and tips
