Bazza LXF regular
Joined: Sat Mar 21, 2009 11:16 am Posts: 1381 Location: Loughborough
Posted: Sat Dec 17, 2011 11:42 am Post subject: Another Python Freebie... An Audio Sweep Generator. |
Hi all...
DM might be interested in this little devil...
A Linux Python 3.x.x code to sweep the audio spectrum from 4KHz down
to 100Hz and back again. (It is effectively a siren sound.)
Written so that anyone can understand how it works...
I will be releasing a Python 2.x.x version to code.activestate.com soon.
Watch out for wordwrapping etc...
Enjoy finding simple solutions to often VERY difficult problems... ;o)
| Code: |
# SweepGen3x.py
# A DEMO Audio Sweep Generator from 4KHz down to 100Hz and back up again
# using standard Text Mode Python. Another kids level piece of code for a very
# simple, FREE, Test Gear project... Hey, it is not perfect but a simple audio
# sweep generator for FREE, what more could you want!
# This working idea is copyright, (C)2010, B.Walker, G0LCU.
# Initially issued to LXF under the MIT licence.
# Written in such a way that anyone can understand how it works.
# Tested on PCLinuxOS 2009 and Debian 6.0.0 using Python 3.1.3 and 3.2.2.
# "/dev/dsp" IS required for this to work; therefore if you haven't got it then
# install "oss-compat" from you distro's repository. Ensure the sound system is
# not already in use.
# It is easily possible to lengthen the higher frequency playing times and VERY
# easily alter the output level and to speed up or slow down the sweep speed.
# I'll let the big guns do that for you...
# IMPORTANT NOTE:- Every EVEN number of bytes is a symmetrical "square" wave BUT
# every ODD number of bytes has preference for the "space" by one byte.
# To run this DEMO type at the Python prompt......
# >>> exec(open("/full/path/to/SweepGen3x.py").read())<RETURN/ENTER>
# ......and away you go.
# Note:- NO import[s] required at all, good eh! ;o)
def main():
# Set all "variables" as globals, my choice... ;o)
global mark
global space
global freq
global stringlength
global n
global sweep
# Allocate initial values.
mark=b"\xff"
space=b"\x00"
freq=mark+space
# 8KHz is the default sample speed of the sound system.
# Therefore this sets the lowest frequency, 8KHz/80=100Hz...
stringlength=80
n=0
sweep=0
# A simple screen clear and user screen for a default Python window...
for n in range(0,40,1):
print("\r\n")
print("Sweep Generator DEMO from 4KHz down to 100HZ and back again...\n")
print("This just gives 5 SIREN like sweeps but it is enough for this DEMO...\n")
print("Copyright, (C)2010, B.Walker, G0LCU.\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n")
# Open the audio device, "/dev/dsp" for writing.
audio=open("/dev/dsp", "wb")
# Sweep for five times only for this DEMO...
while 1:
freq=mark+space
stringlength=80
n=0
while sweep<=4:
# Sweep down from 4KHz to 100Hz.
audio.write(freq)
# Add a trailing 0x00 byte.
freq=freq+space
# Quit when length of "freq" byte-string is 80 bytes.
if len(freq)>=stringlength: break
audio.write(freq)
# Add a leading 0xff byte.
freq=mark+freq
while 1:
# Sweep back up again from 100Hz to 4KHz.
# Start with an empty byte-string.
freq=b""
# Now create a new byte square wave byte-string.
for n in range(0,int((stringlength)/2),1):
freq=freq+mark
freq=freq+space
audio.write(freq)
# Create a new byte-string reduced by one byte.
# This removes one 0xff byte.
stringlength=stringlength-1
# Quit when length of "freq" byte-string is 2 bytes.
if len(freq)<=2: break
freq=b""
# Now create a new byte-string reduced by one byte.
freq=freq+mark
for n in range(0,int(((stringlength)/2)+1),1):
freq=freq+space
audio.write(freq)
# This removes one 0x00 byte.
sweep=sweep+1
# Ensure a complete exit from the loop.
if sweep>=5: break
# On exit ensure the audio device is closed.
audio.close()
main()
# End of SweepGen3x.py DEMO...
# Enjoy finding simple solutions to often VERY difficult problems... ;o)
Enjoy banging the metal and getting something useful for your home
electronics workbench...
Bazza, G0LCU... _________________ 73...
Team AMIGA... |
