Upgrade help
Upgrade help
Postby heiowge » Sat Dec 10, 2011 11:33 am
Thanks to Mr taxman, I've just upgraded my old eeepc to a new one. This is the one I got yesterday:
http://uk.asus.com/Eee/Eee_PC/Eee_PC_10 ... ifications
I've wiped off Windows and installed Mint 11 (and am persuing a windows refund with asus), but I have a couple of queeries.
1) The spec says Dual Core, but the system monitor clearly shows 4 cores. ???
2) I want to upgrade to 2 GB RAM, but I'm not sure exactly what to get. My brother upgraded his laptop and got the wrong speed. He had DDR3 10xx and bought 1333. The new stuff doesn't work. I don't want to make the same mistake. I've opened up the port and there's nothing on the visible side of the RAM.
Can anyone help here? Ta.
Postby nelz » Sat Dec 10, 2011 11:38 am
1) Hyperthreading?
2) Go to Crucial's web site, they have a memory selector where you tell them what you've got and they show the correct options.
Postby heiowge » Sat Dec 10, 2011 11:53 am
Thanks. Scan done. They recommend this:
http://www.crucial.com/uk/store/mpartsp ... 34A5CA7304
Which looks exactly like this:
http://www.amazon.co.uk/204-pin-SODIMM- ... ers_text_b
Which is about £3 cheaper.
Just to check... am I being an idiot and missing something or should I get the amazon RAM?
Postby nelz » Sat Dec 10, 2011 2:10 pm
The part numbers are different... are you feeling lucky?
Postby towy71 » Sat Dec 10, 2011 2:14 pm
I would buy from Crucial, but then I've always bought from Crucial and had excellent service including replacement for getting the wrong module, my mistake, doh!
Just saying ;-)
Postby PCNetSpec » Sat Dec 10, 2011 4:40 pm
Specs are exactly the same:
http://www.crucial.com/uk/store/partspe ... 5664BC1339
DDR3 PC3-10600 • CL=9 • Unbuffered • NON-ECC • DDR3-1333 • 1.5V • 256Meg x 64
So it *should* be fine ..
But at only + £3 I'd buy from Crucial, specifically for the -
Guaranteed-compatible with the ASUS Eee PC 1015PX
statement, and as towy71 mentions, the known after sales service.
Linux in the UK
The Linux Community Forum
PCNetSpec
