Another Python Freebie, DC_IN.py...
Postby Bazza » Sun Dec 04, 2011 3:01 pm
Hi all...
I recently uploaded this to <http://code.activestate.com/> and thought I
would share it with you lot... Another bit of my lateral thinking and has
opened up new avenues for experiment like a text mode Python Audio
I/O Modem using the audio socket(s) on my netbook, notebook and
laptop, a la Sinclair Spectrum Load/Save modem... ;o)
Watch for word wrapping etc...
# DC_IN.py
# This DEMO shows how to get DC, (Direct Current), into a computer without
# the need for Integrated Cirduits, USB, Serial, Parallel etc, etc...
# It is used in this code as a very simple Logic Probe that will give some
# indication of a Logic 0, 1 or indeterminate. Only the external microphone input
# is required. "/dev/dsp" IS required so install "oss-compat" from your distro's
# repository if you do not have "/dev/dsp"...
# Ensure the sound system is not in use, and, use the OS's mixing facilities to
# set any input and output levels...
# Tested on Debian 6.0.0 using Python 3.1.3 and PCLinuxOS 2009 using Python 3.2.2.
# (C)2010, B.Walker, G0LCU. Now issued as Public Domain.
# Written in such a way that anyone can understand how it works.
# A very simple VCO, (Voltage COntrolled Oscillator), can be found here...
# http://www.4qdtec.com/mvbz/vco2.gif
# Assume a supply rail of 5 Volts to the VCO along with the circuit of the probe below...
# +5 Volt rail on VCO, (Vcc).
#  O-------------------------+
#                       D2. / \
# 1-4 Volt VCO I/P, (Vc).    |
#  O--------o---/\/\/\---o---o---/\/\/\---0 Probe I/P.
#           |     R2.    |         R3.
#  O       <             | +
#  |   R1. <            / \ D1.
#  +--------o------------o-------o--------O -VE.
# 0 Volts.                       |
#                             ---+--- GND.
# Parts List.                 ///////
# R1 = 1 MegOhm.
# R2, R3 = 470 Ohms.
# D1, D2 = 1N4148 Diodes.
# All tolerances are wide open.
# Sundries, stripboard, wire, etc...
def main():
   # Make variables global; my choice... ;o)
   global record
   global n
   global freq
   global logic
   global LED
   global colour
   # Set the startup values...
   freq=0
   record=b"?"
   n=0
   logic="0"
   # Use "H" for this DEMO although the commented out "LED" may look better.
   LED="H"
   # LED=chr(0x2588)
   colour="\033[1;32m"
   while 1:
      # Do a 1 second recorded burst...
      audio=open('/dev/dsp', 'rb')
      # "record" is the "binary string" to be counted...
      record=audio.read(8000)
      audio.close()
      # Enter another loop to do the count...
      n=0
      freq=0
      while 1:
         # A VCO with a mark to space ratio of 1 to 1 will be used for this DEMO,
         # so "wait" until a "space" is found.
         # (For those that don't know.)
         # Square wave:-    | Mark |Space |
         # This ensures that the loop cycles when NO input is
         # applied to the microphone socket.
         # Exit this loop when "mark" is found or n>=8000...
         while record[n]<=127:
            n=n+1
            # Ensure as soon as n>=8000 occurs it drops out of the loop.
            if n>=8000: break
         # Ensure as soon as n>=8000 occurs it drops completely out of this loop.
         if n>=8000: break
         # Now the "mark" can loop until a "space" is found again and the whole
         # can cycle until n>=8000...
         while record[n]>=128:
            n=n+1
            if n>=8000: break
         if n>=8000: break
         # "freq" will become the frequency of a symmetrical waveform
         # when the above loops are finally exited, n>=8000...
         # Tick up the freq(uency) per "mark to space" cycle.
         freq=freq+1
         # Just 3 levels are displayed here but with more "if" statements much more
         # accuracy and range is easily possible. Also "look up tables" could be used if desired...
         # Set colour to Green for Logic 0, Red for Logic 1 and Yellow for indeterminate.
         # Logic 1 is approximately greater than 4 Volts.
         if freq>=3000:
            logic="1"
            # Red...
            colour="\033[1;31m"
         # Logic 0 is approximately less than 1 Volt.
         if freq<=300:
            logic="0"
            # Green...
            colour="\033[1;32m"
         # Indeterminate is between 1 and 4 Volts and/or a slow oscillation being measured...
         if freq>=301 and freq<=2999:
            logic="indeterminate"
            # Yellow...
            colour="\033[1;33m"
      # An ultra simple clear screen line...
      # This line is not needed for the demo but added for fullness...
      print("\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n")
      # Now display the value in the same place on screen every time.
      # This assumes a 24 or 25 line Python Shell window. Just modify to
      # suit your particular Shell that you use...
      print("\033[0m\nSimple DC Input in the guise of a TTL level Logic Probe.\n")
      print("(C)2010-2011, B.Walker, G0LCU. Issued as Public Domain.\n\n\n")
      # Print a large coloured square "LED" for quick and easy viewing.
      for n in range (0,3,1):
         print("                                     "+colour+LED+LED+LED+LED+LED+LED)
      print("\033[0m\n\n\nLogic level is "+colour+logic+"\033[0m...\n\n\n\n\n\n\n\n\n")
main()
# End of DC_IN.py DEMO.
# Enjoy finding simple solutions to often very difficult problems.
73...
Team AMIGA...
Bazza
