Python Help
Postby Bazza » Sun Dec 04, 2011 2:24 pm
Not really studied the code except to say......
Check all of your single quotes as they look wrong they should be
"characters" or 'characters'
Team AMIGA...
Postby evilnick » Sat Jan 07, 2012 11:23 pm
The underscore characters you are using (I think just for effect) are unicode. You either need to define a unicode encoding at the top of the file or change them for something else like '-'. All the quotes look wrong, as has been mentioned.
also the if __name__ = '__main__' bit is the main executable code in the file, so it shouldn't be indented like that, you have it as part of the main() function, but actually it is the bit that invokes the main() function:
from django.utils.encoding import smart_str, smart_unicode
import twitter
CusKey = "XX"
CusSec = "XXX"
AccTokKey = "XXXX"
AccTokKeySec = "XXXXX"
def main():
   api = twitter.Api(consumer_key = CusKey, consumer_secret = CusSec, access_token_key = AccTokKey, access_token_secret = AccTokKeySec)
   timeline = api.GetFriendsTimeline()
   for status in timeline:
        print'ascii', 'ignore'), '----', status.text.encode('ascii', 'ignore')
if __name__ == '__main__':
