Fun and games with expect
Postby maxeaves » Mon Nov 14, 2011 2:42 pm
Dear all,
I think this should be an easy answer, but I cannot find out how to do this.
What I have is the following: I want to telnet into a switch, and retrieve the output to a text file. I'm using expect - so far I have is:
#!/bin/bash
expect << EOF
set timeout 20
spawn telnet xxx.xxx.xxx.xxx
expect "telnet@******************>"
send "en\r"
expect "Password:"
send "*******\r"
expect "*#"
send "show int brief\r"
expect "*"
send "exit\rexit\r"
exit
EOF
What I cannot seem to get to work is the output from the SHOW INT BRIEF command to be outputted to a file.....I've tried send "show int brief\r" >> outputfile.txt but it doesn't seem to like the output. I've also tried the send_log and file_log options, but this also doesn't do want I want it to do.
Suggestions ?
Thanks
Max
maxeaves
Postby PeterM » Thu Dec 01, 2011 1:07 pm
Afternoon Max,
I am also having a big fight with expect but I might be able to help a little. I can get it writing to a file but it puts the wrong thing in. I have put in the lines
set fid [open wombat.txt w+];
set capturedinfo $expect_out(buffer);
puts $fid $capturedinfo;
Which opens a file called wombat.txt for writing and puts the expect_out buffer into a variable which in turn is written to the file.
My problem is that it is writing output from a previous step into the file and actually prints out the information I want twice.
Here's my work-in-progress script:
#!/usr/bin/expect
# Usage: gwinfo userid password
set timeout 10
set mgwyip [lindex $argv 0]
set userid [lindex $argv 1]
set password [lindex $argv 2]
match_max 100000
puts "logging in to $mgwyip\r"
spawn ssh $userid@$mgwyip
expect {
-re "continue connect" {send "yes\r"}
timeout {puts "Host is known"}
expect {
-re "(P|p)assword: " {send "$password\r"}
-re "Warning:" {send "$password\r"}
-re "Connection refused" {puts "Host error -> $expect_out(buffer)";exit}
-re "Connection closed" {puts "Host error -> $expect_out(buffer)";exit}
-re "no address.*" {puts "Host error -> $expect_out(buffer)";exit}
timeout {puts "Timeout error. Device down or unreachable? ";exit}
expect {
-re "super" {send "show image version\r"}
timeout {puts "Error reading prompt -> $expect_out(buffer)";exit}
expect {
-re "super" {send "exit\r"}
set output $expect_out(buffer)
send "exit\r"
puts "$output\r\n"
It's a bit messy but that's because I keep changing bits, adding bits and removing bits.
If you get your script to work, could you post the details?
Cheers
Pete
PeterM
More Fun and games with expect
Postby PeterM » Thu Dec 01, 2011 1:26 pm
Me again,
Just as I was starting to go insane, I was talking the problem out loud to the cat and it suddenly hit me. I had the write the file bit in the wrong place.
Here's some working code for you:
#!/usr/bin/expect
set timeout 10
match_max 100000
expect {
expect {
expect {
expect {
send "exit\r"
puts "$output\r\n"
Now it just puts what I want in a file called wombat.txt ready for further processing. :D
Probably need to tidy up a bit now, but at least I'm happy again.
Cheers
Pete
PeterM
Postby PeterM » Thu Dec 01, 2011 1:28 pm
And yes, you did read it correctly, I was talking to the cat :oops:
I think the cat was listening, the expression didn't change much but at least it didn't roll it's eyes.
PeterM
