Smallest linux box available?
Postby jarlath » Thu Oct 20, 2011 7:53 pm
I remember seeing the occassional review of a very small linux server in LXF over the years. They were about the size of a socket adaptor and you could run a server off it.
Does anyone know what these were? I'm doing a lot of PHP and running the lot from a mains outlet with a wireless connection would be ideal instead of having an old headless box uglifying the front room.
Many thanks,
Jarlath
jarlath
Postby Rhakios » Thu Oct 20, 2011 8:05 pm
Would it be the Sheevaplug you are thinking of? There are a couple of others.
Postby jarlath » Thu Oct 20, 2011 8:18 pm
Rhakios wrote:Would it be the Sheevaplug you are thinking of? There are a couple of others.
Rhakios, thank you so much. I couldn't remember any of them but yes, that was one of them. And I have a starting point for some searching now so thanks a lot!
I may get that one, but I'll continue to see if there's an even more convenient model. My fantasy is something that basically *is* a wall plug, with an ethernet connection and built in wifi. Fat chance eh?
Best,
Jarlath
jarlath
Postby Rhakios » Thu Oct 20, 2011 8:24 pm
A bit like Apple's Airport Express then? I don't know if anyone has succeeded in hacking one to get Linux on it, a quick glance at Google would suggest not.
Postby jarlath » Fri Oct 21, 2011 12:23 am
Oh well, if nothing turns up then Sheeva will do the job very nicely. Thanks for that.
Jarlath
jarlath
Postby Dutch_Master » Fri Oct 21, 2011 2:34 am
It might not be what you're after, initially, but have a look here:
http://www.linuxformat.com/forums/viewtopic.php?t=13330
Postby jarlath » Fri Oct 21, 2011 8:34 am
Thanks Dutch_M. It's close alright, but I think the Sheeva plug might be more convenient for my purposes.
jarlath
Postby PCNetSpec » Fri Oct 21, 2011 2:36 pm
Globalscale Guruplug Server:
http://www.globalscaletechnologies.com/ ... ndard.aspx
or Guruplug Server Plus:
http://www.globalscaletechnologies.com/ ... -plus.aspx
Globalscale Dreaamplug:
http://www.globalscaletechnologies.com/ ... evkit.aspx
or if you want HDMI...
Globalscale D2:
http://www.globalscaletechnologies.com/ ... -plug.aspx
the top 3 will plug directly into the mains socket, not sure about the D2
See the "Physical Dimensions" links.
Linux in the UK
The Linux Community Forum
PCNetSpec
Postby leke » Sat Oct 22, 2011 2:25 pm
How about the insanely cheep raspberrypi?
Last time I checked, I think it was due out November (birthday time :)).
Might have to get 2. One for me and one for the boy.
leke
