How do I ring my bell?
Postby kev » Wed Oct 19, 2011 10:44 pm
Hello
I want to write a script that will ring the PC's bell under certain conditions.
The bell works at Boot-time, so I know that it is OK.
I have tried the Konsole:
Settings > Bell > set to system bell
and then echoing 0x07 as well as \a
I have also tried echoing 0x07 and \a in an ordinary { Ctrl-Alt-F2 } terminal.
but it's silent.
What will make it ring please?
kev
Postby Rhakios » Wed Oct 19, 2011 10:55 pm
Doesn't beep do that? Sadly this PC doesn't have an internal speaker, so I can't test it. You might need to install beep, but it's found in most repos I've seen.
Postby Ram » Thu Oct 20, 2011 12:28 pm
You can ring Solaris' bell with
echo \\a
Thats with ksh for the shell.
Postby MartyBartfast » Thu Oct 20, 2011 1:13 pm
echo -e \\a
works in bash.
MartyBartfast
Postby kev » Sat Oct 22, 2011 10:09 pm
Well, thanks for your ideas.
Although they didn't work, they did give me ideas for searching the 'net.
The answer in Mandriva is to do the following as Root:
modprobe pcspkr
and then Ctrl^G and your ideas do work.
Also:
xset -b
turns it off; and then:
xset b
turns it back on again.
Unfortunately, I am using Knoppix mostly {kernel 2.6.19} and modprobe gives a FATAL error message.
Ubuntu will load the module, but the bell remains silent.
All of which has overtones of M$.
Knoppix 5.1
kev
Postby kev » Mon Oct 24, 2011 8:01 pm
I have now found out that in Ubuntu:
The missing PC bell is a BIG issue;
more than that: it is a thoroughly disgraceful mess, the likes of which M$ users niether have nor will EVER have to put up with.
Read this ubuntu thread from post #79 onwards.
Knoppix 5.1
kev
Postby Rhakios » Mon Oct 24, 2011 9:58 pm
Essentially, the problem is that Mark Shuttleworth wants your computer to go Bongggg!!!, like a Mac does on startup. However, as he can't achieve this, he's had them disable the bell.
Of course, this might be entirely untrue. :)
Postby Ram » Tue Oct 25, 2011 12:57 am
Rhakios wrote:Essentially, the problem is that Mark Shuttleworth wants your computer to go Bongggg!!!, like a Mac does on startup. However, as he can't achieve this, he's had them disable the bell.
Then it could just as easy be true, since I keep having to re-install alsa after every kernel update as sound only work via head phones not the speakers, also effecting my netbook now with Mint 8 and the fix I use for my laptop doesnee work Jimmy.
