nelz Moderator
Posted: Thu Dec 15, 2011 8:40 am Post subject: |
That's OK, and useful. I don't have Ubuntu installed here, so I couldn't be sure what was on line 20. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Stanoz
Posted: Fri Jan 06, 2012 12:39 pm Post subject: |
$ sudo apt-get install --reinstall xserver-xorg-core
[sudo] passworld for stanley-bob-carl-ozoemena:
Reading package lists... Done
Building dependency tree
Reading state information ... Done
The following package was automatically installed and is no longer required:
localechooser-data
Use 'apt-get autoremove' to remove them.
The following extra packages will be installed:
xserver-common
The following packages will be upgraded:
xserver-common xserver-xorg-core
2 upgraded, 0 newly installed, 0 to remove and 485 not upgraded.
Need to get 1,637kB of archives.
After this operation, 0B of additional disk space will be used.
Do you want to continue [Y/n]? y
WARNING: The following packages cannot be authenticated!
Install these packages without verification [y/N]? y
Err http://us.archive.ubuntu.com/ubuntu/ maverick-updates/main xserver-common all 2:1.9.0-0ubuntu7.3
Could not resolve 'us.archive.ubuntu.com'
Err http://us.archive.ubuntu.com/ubuntu/ maverick-updates/main xserver-xorg-core i386 2:1.9.0-0ubuntu7.3
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/x/xorg-server/xserver-common_1.9.0-0ubuntu7.3_all.deb Could not resove 'us.archive.ubuntu.com'
Failed to fetch http://us.archive.ubuntu.com/ubuntu/pool/main/x/xorg-server/xserver-xorg-core_1.9.0-0ubuntu7.3_i386.deb Could not resodve 'us.archive.ubuntu.com'
E: Unable to fetch some archives, maybe run apt-get update or gtry with --fix-missing?
____________________________________________________________
GNU nano 2.2.4 File: /usr/share/X11/xorg.conf.d/10-evdev.conf
# Catch-all evdev loader for udev-based systems
# We don't simply match on any device since that also adds accelerometers
# and other devices that we don't really want to use. The list below
# matches everything but joysticks
Section "InputClass"
Identifier "evdev pointer catchall"
MatchIsPointer "on"
MatchDevicePath "/dev/input/evvent*"
Driver "evdev"
EndSection
Identifier "evdev keyboard catchall"
MatchIsKeyboard "on"
MatchDevicePath "/dev/input/events*"
Driver "evdevv"
EndSection
Section "In
...happy new year, you guys... :0)
[ Read 21 lines (Warning: NO write permission) ]
^G Get Help ^O WriteOut ^R Read File ^Y Prev page ^K Cut Text ^C Cur Pos
^X Exit ^J Justify ^W Where Is ^V Next Page ^U UnCut Text ^ To Spell |
nelz Moderator
Posted: Fri Jan 06, 2012 12:53 pm Post subject: |
The file is clearly corrupted, and apt-get warned you it could not be verified. Try using a different repository. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Stanoz
Posted: Fri Jan 06, 2012 2:37 pm Post subject: |
I wonder how I'm going to do that...
(I guess I gotta google it first, or else the "exper-witnesses" might think me unserious...)
Stanoz
Posted: Mon Jan 16, 2012 11:51 am Post subject: |
Alright. I'm on the verge of giving up...
You advise me to format, Sir?
nelz Moderator
Posted: Mon Jan 16, 2012 12:40 pm Post subject: |
If you keep downloading the same corrupt file, reformatting won't make any difference (unless you are able to reformat the server ). Select a different repository in Synaptic and try installing the package again. Emptying apt-get's cache is a wise move too.
Filing a bug report is probably a good idea too. If the file on the server really is corrupt, they need to know. If not, you'll know it's at your end. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
Stanoz
Posted: Sun Jan 29, 2012 9:40 am Post subject: |
| Thanks, Nez. I've reformatted and switched to Lucid. :0) Cheers. |
