wireless dongles
wireless dongles
Postby cbuffer » Fri Sep 30, 2011 5:13 pm
I recently bought an Edimax EW-7811Un device. If I plug it into this laptop while running Sabayon from a recent cover DVD it works perfectly without me having to do anything. It wont work with Fedora, Centos or Linux Mint, and if I try to install the linux driver supplied, all three throw up an error at "make". Has anyone else had this problem, and has anyone found any other distro where it just works. Sabayon was the last one from which I expected out of the box use!
TIA
Ken
cbuffer
Postby Rhakios » Fri Sep 30, 2011 6:24 pm
Removed duplicate thread.
wireless dongles
Postby cbuffer » Fri Sep 30, 2011 7:57 pm
Sorry about that - I couldn't see how to do it.
Ken
cbuffer
Postby Rhakios » Fri Sep 30, 2011 8:24 pm
I'm pretty sure members can delete their own posts, but as I only see the controls available to me as a mod, I'm not sure if they appear in the same place on your view of the page. :?
Postby PCNetSpec » Fri Sep 30, 2011 9:42 pm
Which driver are you trying ?
From what I gather, you want the RTL8129CU driver from HERE
Source -
http://ubuntuforums.org/showthread.php?t=1744371
Linux in the UK
The Linux Community Forum
PCNetSpec
