Haiku Installation
Haiku Installation
Postby eipapp » Wed Aug 31, 2011 6:57 pm
Tried to install Haiku to USB as suggested in the magazine (LXF 149) page 127. All goes well until I get to the point where it says to enter:
dd if=filename.img of=/dev/name
I've tried various scenarios for filename and name with no success. Can someone help me define exactly what I should be putting in place of "filename" and "name" or where I can find this information ??
Sorry to say, I'm clueless...........
Thanks,
Bruce
eipapp
Postby ajgreeny » Wed Aug 31, 2011 8:03 pm
Try
dd if=haiku-r1alpha3-anyboot.image of=/dev/sdb
Normally an image file is named <filename>.img, but for some reason this one seems to be <filename>.image. I presume that will make no difference to dd, and the image will still be copied.
/dev/sdb is just my suggestion of what you may have as your USB drive, but you can find it easily with
sudo fdisk -l
If you have only one hard drive and no other external disks attached it is most likely to be /dev/sdb
ajgreeny
