The C Primer
The C Primer
Postby elija » Mon Aug 29, 2011 7:50 am
By co-incidence I started to teach myself c a couple of months ago and was pleasantly surprised at how easy the the code was to follow and understand.
However, I was getting warnings:
warning: assignment makes pointer from integer without a cast
and when I tried to cast I got
warning: cast to pointer from integer of different size [-Wint-to-pointer-cast]
I did a bit of googling and asking around and learned that code will run without the appropriate header files being included and about the -Wall switch to gcc to show all warnings.
To cut a long story short, here is the code with all the warnings fixed.
#include <stdio.h>
#include <unistd.h>
#include <stdlib.h>
//  Missing headers
#include <string.h>
#include <sys/types.h>
#include <sys/wait.h>
int parse(char **args)
   static char line[100];
   printf("> ");
   if (gets(line) == NULL)
      return -1;
   // cast strtok return to char *
   *args++ = (char *)strtok(line, " \t");
   // put paranthesis around assignment
   while ((*args++ = (char *)strtok(NULL, " \t")));
   return 1;
//  main should return int
int main()
   char *args[20];
   while(parse(args) > 0) {
      if (fork() == 0) {
         execvp(args[0], args);
         printf("%s not found\n", args[0]);
         exit(1);
      } else {
         wait(0);
   return 0;
I'm looking forward to the next instalment.
"Sometimes free software isn't free and sometimes free software isn't free. Sometimes it's both free and free and sometimes it's neither free nor free! Why is this so hard to explain" - Elija
elija
Postby elija » Mon Aug 29, 2011 8:24 am
Having an interesting discussion on another forum about the danger of gets. It can't check the size of the buffer passed in so is susceptible to buffer overflow attacks.
According to the man page, the lsb deprecates the function anyway.
Here is parse using fgets instead. fgets includes the carriage return in the string whereas gets doesn't.
   int l = 0;
   printf("> ");
   if (fgets(line, 100, stdin) == NULL)
      return -1;
   //  There is probably a simpler way of removing the carriage return
   l = strlen(line);
   if (10 == *(line + (l-1))) {
      *(line + (--l)) = '\0';
   return 1;
Interestingly, gcc 4.4.4 shows a warning when you use gets but gcc 4.6.1 doesn't.
elija
