Rhakios Moderator
Posted: Thu Aug 18, 2011 8:15 pm Post subject: |
On my bookshelf, is one answer.
If you are a subscriber, then have you had any luck contacting the subs department? If you've had no joy from them, then Katy Holman: katy.holman@futurenet.com has worked many minor miracles for many disgruntled subscribers. So try emailing her with a brief outline of your problem. _________________ Bye, Rhakios |
