form data isn't making it to the database. any help?
Postby rcayea » Mon Aug 15, 2011 11:48 pm
Hey everyone,
I am in need of that high quality help I receive when visiting this website. In short, I have a php script that is supposed to automatically submit data to a MySQL database but the data doesn't seem to make it to the database. I am not good at debugging and I am not getting any errors on the pages when I submit an entry.
Basically I have this code which takes in the information and as you know/can tell it calls on another php script to do the auto submit to the database. Here is this code:
</head>
<?php
include('../templates/bodyandlogo.htm');
<?php
include('../templates/navmenu.htm');
<br />
<br />
<h1>PoemScribe: Order Form</h1>
<br />
<br />
<p>Please complete the form below and click submit to order your personalized poem.</p>
<br />
<br />
<div id="form">
<form action="../php_scripts/orderform.php" method="post">
<label for="firstname">First Name:</label>
<div class="input"><input type="text" id="firstname" name="firstname" /></div><br />
<label for="lastname">Last Name:</label>
<div class="input"><input type="text" id="lastname" name="lastname" /></div><br />
<label for="email">Email:</label>
<div class="input"><input type="text" id="email" name="email" /></div><br />
<label for="selectpoemtype">Select Poem Type:<br />
4-Line Poem: $15
8-Line Poem: $25
12-Line Poem: $40
16-Line Poem: $50
20-Line Poem: $75
Please type in your desired poem length. Example: "4line".
</label><br />
<div class="input"><input type="text" id="selectpoemtype" name="selectpoemtype" /><br />
<br />
<br />
<label for="keynames">"Key names to include?"</label>
<div class="input"><input type="text" id="keynames" name="keynames"/></div><br />
<label for="specificwords">Any specific words you would like to include in your poem?</label>
<div class="input"><input type="text" id="specificwords" name="specificwords" /></div><br />
<label for="poemisfor">Who is the poem for?</label>
<div class="input"><input type="text" id="poemisfor" name="poemisfor" /></div><br />
<label for="relationship">Relationship to you?</label>
<div class="input"><input type="text" id="relationship" name="relationship" /></div><br />
<label for="occasion">What is the occasion for this poem?</label>
<div class="input"><input type="text" id="occasion" name="occasion" /></div><br />
<label for="overallmessage">What do you want the overall message of this poem to be?</label>
<div class="input"><input type="text" id="overallmessage" name="overallmessage" /></div><br />
<label for="anythingelse">Any other information you would like for me to know?</label>
<div class="input"><input type="text" id="anythingelse" name="anythingelse" /></div><br />
<div class="input"><input type="submit" value="Submit" name="submit"</div>
</form>
</div><!--form-->
<br />
<br />
<?php
include('../templates/footer.htm');
And then the code that is called on (the script called orderform.php):
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head><title>PoemScribe Order Form</title>
</head>
<body>
<h2>PoemScribe</h2>
<?php
$email = "myemail@gmail.com"; // Email to notify on error
$first_name = $_POST['firstname'];
$last_name = $_POST['lastname'];
$email = $_POST['email'];
$select_poem_type = $_POST['selectpoemtype'];
$key_names = $_POST['keynames'];
$specific_words = $_POST['specificwords'];
$poem_is_for = $_POST['poemisfor'];
$relationship = $_POST['relationship'];
$occasion = $_POST['occasion'];
$over_all_message = $_POST['overallmessage'];
$anything_else = $_POST['anythingelse'];
$dbc = mysqli_connect('localhost', 'login', 'password', 'database'); " .
or die('Error connecting to MySQL server.');
$query = INSERT INTO poem_orders '(firstname, lastname, email, selectpoemtype, keynames, specificwords, poemisfor, " .
"relationship, occasion, overallmessage, anythingelse)" .
"VALUES ('$first_name', '$last_name', '$email', '$select_poem_type' '$key_names', '$specific_words', '$poem_is_for', " .
"'$relationship', '$occasion', '$over_all_message', '$anything_else')";
echo 'Thank you, ' . $firstname . $lastname;
echo 'Thanks for submitting the form.<br />';
echo ' Poem Type: ' . $selectpoemtype;
echo ' Key names to include: ' . $keynames . '<br />';
echo 'Specific Words To Include: '. $specificwords . '<br />';
echo 'Poem is for: ' . $poemisfor . '<br />';
echo 'Relationship: ' . $relationship . '<br />';
echo 'Occasion: ' . $occasion . '<br />';
echo 'Overall Message: ' . $overallmessage . '<br />';
echo 'You also added: ' . $anything_else;
mysqli_close($dbc);
</body>
</html>
Again, I am trying to figure out why my database isn't being populated when someone clicks on the submit button.
Thanks in advance,
Randy
0
rcayea
Postby johnhudson » Tue Aug 16, 2011 6:49 am
There are some obvious imbalances of single and double quotes in the INSERT command; I also don't understand why the values are not part of the same paragraph of text.
Postby rcayea » Tue Aug 16, 2011 1:54 pm
Thanks for the reply. Here is some corrected code. It is getting better but I still get error that query wasn't successful. I fixed the quotes issue, I think.
<?php
      $email = "email@gmail.com"; // Email to notify on error
$query = "INSERT INTO poem_orders (firstname, lastname, email, selectpoemtype, keynames, specificwords, poemisfor, relationship, occasion, overallmessage, anythingelse) VALUES ('$first_name', '$last_name', '$email', '$select_poem_type' '$key_names', '$specific_words', '$poem_is_for', '$relationship', '$occasion', '$over_all_message', '$anything_else')";
$insert = mysqli_query($dbc, $query);
// if query was successful, display message to user:
if($success)
else
     echo 'Error: Query failed.';
mysqli_close($dbc);
</body>
</html>
rcayea
Postby bobthebob1234 » Tue Aug 16, 2011 4:41 pm
I think something is not quite right here.... if you print $query I think you will find that it just says
I don't think that is what you want...
bobthebob1234
Postby johnhudson » Tue Aug 16, 2011 6:18 pm
Try this: I don't understand the point of the second VALUES statement and I have made one subtle change, putting the semi-colon inside the quotation marks around the query. Your previous query was incomplete because the semi-colon was not part of it.
$query = "INSERT INTO poem_orders (firstname, lastname, email, selectpoemtype, keynames, specificwords, poemisfor, relationship, occasion, overallmessage, anythingelse) VALUES ('$first_name', '$last_name', '$email', '$select_poem_type' '$key_names', '$specific_words', '$poem_is_for', '$relationship', '$occasion', '$over_all_message', '$anything_else');"
Postby ollie » Wed Aug 17, 2011 2:55 am
You are also using the variable $email twice. You are setting $email to "myemail@gmail.com" and then 4 lines later setting $email to the submitted email from the form - "$email = $_POST['email'];"
Are you sure this is what you want to do?
Postby rcayea » Fri Aug 19, 2011 7:13 pm
Thanks for the tips. They helped solve the problem.
rcayea
