PCNetSpec LXF regular
Joined: Sun Feb 21, 2010 3:50 pm Posts: 623 Location: Cornwall UK
Posted: Sun Aug 14, 2011 10:44 pm Post subject: |
see the edit above. _________________ WARNING: You are logged into reality as 'root'... logging in as 'insane' is the only safe option.
Linux in the UK
The Linux Community Forum |
petersull
Joined: Sat Aug 13, 2011 11:03 pm Posts: 13 Location: UK
Posted: Sun Aug 14, 2011 10:49 pm Post subject: |
The other command reads as you suggested...
peter@zebidee ~ $ ls -a /opt/cdf/SystemFiles/FrontEnd/Binaries/Linux
. .. .CreationID espeak gltest nbcat sicheck WolframCDFPlayer
peter@zebidee ~ $ md5sum /home/peter/Downloads/CDFPlayer_8.0.3_LINUX.sh
23e97c7a16bcbdd5b3f198b8ae15035b /home/peter/Downloads/CDFPlayer_8.0.3_LINUX.sh
peter@zebidee ~ $ |
Posted: Sun Aug 14, 2011 10:54 pm Post subject: |
What happens if you try to run the executable directly with:
| Code: | | /opt/cdf/Executables/wolframcdfplayer |
Linux in the UK
petersull
Posted: Sun Aug 14, 2011 10:56 pm Post subject: |
Here it is...
peter@zebidee ~ $ /opt/cdf/Executables/wolframcdfplayer
/opt/cdf/Executables/wolframcdfplayer: 233: /opt/cdf/SystemFiles/FrontEnd/Binaries/Linux/WolframCDFPlayer: not found
peter@zebidee ~ $ |
Posted: Sun Aug 14, 2011 11:03 pm Post subject: |
OK, I'm baffled... the directory listing of:
Clearly show the file as present:
| Quote: | | . .. .CreationID espeak gltest nbcat sicheck WolframCDFPlayer |
And it runs perfectly on my Ubuntu 11.04 64bit.
[EDIT]
Can you post the output from:
| Code: | | ls -l /opt/cdf/SystemFiles/FrontEnd/Binaries/Linux |
Expected output:
| Quote: | mark@mark:~/Desktop$ ls -l /opt/cdf/SystemFiles/FrontEnd/Binaries/Linux
total 13048
-rwxr-xr-x 1 root root 17304 2011-08-14 22:42 espeak
-rwxr-xr-x 1 root root 10568 2011-08-14 22:42 gltest
-rwxr-xr-x 1 root root 403144 2011-08-14 22:42 nbcat
-rwxr-xr-x 1 root root 22488 2011-08-14 22:42 sicheck
-rwxr-xr-x 1 root root 12898240 2011-08-14 22:42 WolframCDFPlayer |
Linux in the UK
petersull
Posted: Sun Aug 14, 2011 11:12 pm Post subject: |
Output...
peter@zebidee ~ $ ls -l /opt/cdf/SystemFiles/FrontEnd/Binaries/Linux
total 13048
-rwxr-xr-x 1 root root 17304 2011-08-14 21:54 espeak
-rwxr-xr-x 1 root root 10568 2011-08-14 21:54 gltest
-rwxr-xr-x 1 root root 403144 2011-08-14 21:54 nbcat
-rwxr-xr-x 1 root root 22488 2011-08-14 21:54 sicheck
-rwxr-xr-x 1 root root 12898240 2011-08-14 21:54 WolframCDFPlayer
peter@zebidee ~ $ |
Posted: Sun Aug 14, 2011 11:17 pm Post subject: |
OK, not a permission issue then... sorry but we've reached the end of my knowledge.
Seems odd that the application cannot find the WolframCDFPlayer binary, when the system can clearly see it. _________________ WARNING: You are logged into reality as 'root'... logging in as 'insane' is the only safe option.
Linux in the UK
petersull
Posted: Sun Aug 14, 2011 11:22 pm Post subject: |
OK, and thanks very much for all your effort.
Best regards,
Peter Sullivan. |
arqueware
Posted: Thu Apr 19, 2012 6:26 pm Post subject: Must...install...ia32-libs...argh! <expires> |
| WolframCDFPlayer is a 32-bit java app. Must...install...ia32-libs...argh! <expires> |
