Android Get Started LXF145 problem
Postby skyde » Wed Jul 06, 2011 4:39 pm
I thought I have followed the tutorial to the letter and when I try to
"ant debug" I get :
compile:
    [javac] /home/skyde/android/android-sdk-linux_x86/tools/ant/main_rules.xml:384: warning: 'includeantruntime' was not set, defaulting to build.sysclasspath=last; set to false for repeatable builds
    [javac] Compiling 2 source files to /home/skyde/android_code/countdown/bin/classes
    [javac] /home/skyde/android_code/countdown/src/com/example/countdown/CountdownActivity.java:28: cannot find symbol
    [javac] symbol  : variable timeentrybox
    [javac] location: class com.example.countdown.R.id
    [javac]       final EditText timeEntry = (EditText) findViewById(R.id.timeentrybox);
    [javac]                                                              ^
    [javac] /home/skyde/android_code/countdown/src/com/example/countdown/CountdownActivity.java:29: cannot find symbol
    [javac] symbol  : variable startbutton
    [javac]       Button startButton = (Button) findViewById(R.id.startbutton);
    [javac]                                                      ^
    [javac] 2 errors
I even copied the code from the DVD and still getting the same problem.
My first instinct was to replace timeentrybox with timeEntry and startbutton with startButton but that did not work.
Best regards,
~skyde
skyde
Postby skyde » Wed Jul 06, 2011 7:07 pm
I figured it out myself. My main.xml in res/layout was buggy.
skyde
