A Kids Level Python Project I Am Working On.
Postby Bazza » Sun Jun 26, 2011 10:07 pm
Hi all...
Here is the preliminary of a Data-Logger/Transient-Recorder project for
kids that I am working on. It uses the Arduino Diecimila Dev Board and
works in Linux, Windows, Classic AMIGA and WinUAE from Python
1.4.0 to Python 2.6.6.
I haven't got Python 2.7.x so if anyone is able to test for that then I
would be grateful.
It runs in DEMO mode but to enable the Arduino access just change
the line demo=1 to demo=0 and ensure that the correct serial port
devices are changed too. The device numbers are for my setups only.
Watch for any wordwrapping etc...
# DataLogger.py
# (C)2011, B.Walker, G0LCU.
# A kids level project using the Arduino Diecimila and other related boards as an
# analogue input for use as a Data Logger. The accuarcy is 8 bit depth but the
# display is only 4 bit depth due to the limitations of text mode.
# This is a feeder upload only, it is no where near completion.
# This code defaults to DEMO mode but the crucial Arduino code is added and just
# requires the line "demo=0" to access the board and the correct device number to
# be changed. Later versions of Arduino now use /dev/ttyACMx in Linux and I have
# not got one to test with, so if any of you guys are willing to experiment by
# changing the Linux device type and number and let me know how you get on with
# it, then thanks.
# The test *.pde file for the Arduino Diecimila Board is here:-
# http://code.activestate.com/recipes/577625-arduino-diecimila-board-access-inside-winuae-demo/?in=user-4177147
# Tested on Windows XP using Python 2.4.2, Vista using Python 2.6.1, PCLinuxOS 2009 using
# Python 2.5.2, Debian Linux using Python 2.6.6, stock AMIGA A1200 using Python 1.4.0 and
# WinUAE with standard AMIGA OS 3.1 using Python 2.0.1.
# DEMO mode ONLY works in E-UAE with standard AMIGA OS 3.1 and Python 1.4.0 or Python 2.0.1.
# NOTE:- The Linux platforms assume running Python from a root default Terminal.
import sys
import os
import random
import time
def main():
   global LoggerScreen
   global LoggerWindow
   global savefile
   global plot
   global position
   global horiz
   global demo
   global pause
   global pausestring
   global serialport
   global pointer
   global mybyte
   global grab
   # global n
   LoggerScreen="(C)2011, B.Walker, G0LCU."
   LoggerWindow="Data_Logger-Transient_Recorder."
   savefile="/tmp/LoggerStartup.txt"
   demo=1
   plot=0
   horiz=1
   position=79
   pause=1
   pausestring="1"
   # The latest device name for current Arduino variants, (01-01-2011).
   serialport="/dev/ttyACM0"
   pointer=" "
   mybyte=" "
   grab=255
   # n=0
   if sys.platform=="amiga":
      # The AMIGA serial port may need to be changed to 1200 baud, no parity,
      # 8 bit data and 1 stop bit, this applies to WinUAE too.
      serialport="SER:"
   if sys.platform=="linux2":
      # Assumed running from root for the time being.
      # /dev/ttyUSB0 the device on my test systems, the Arduino Diecimila Board.
      # It may need to be changed for your needs.
      serialport="/dev/ttyUSB0"
      os.system("chmod 666 "+serialport)
      os.system("stty -F "+serialport+" 1200")
      os.system("stty -F "+serialport+" raw")
   if sys.platform=="win32":
      # This is the COM port number generated on a test system.
      serialport="COM3:"
      os.system("MODE "+serialport+" BAUD=1200 PARITY=N DATA=8 STOP=1 to=on")
   def clrscn():
      if sys.platform=="amiga": print "\f",
      if sys.platform=="linux2": print os.system("clear"),chr(13),"  ",chr(13),
      if sys.platform=="win32": print os.system("CLS"),chr(13),"  ",chr(13),
   def startscreen():
      global savefile
      if sys.platform=="amiga": savefile="S:LoggerStartup.txt"
      if sys.platform=="linux2": savefile="/tmp/LoggerStartup.txt"
      if sys.platform=="win32": savefile="C:\\Windows\\Temp\\LoggerStartup.txt"
   def savescreen():
      global LoggerWindow
      global savefile
      global LoggerScreen
      LoggerWindow=open(savefile,"wb+")
      LoggerWindow.write(LoggerScreen)
      LoggerWindow.close()
   def doplot():
      global horiz
      global position
      global savefile
      global LoggerWindow
      global LoggerScreen
      global demo
      global pause
      global pausestring
      global plot
      global pointer
      global mybyte
      global serialport
      global grab
      horiz=1
      while horiz<=64:
         # Generate a byte as though grabbed from Arduino.
         if demo==1: grab=int(random.random()*256)
         # Generate a byte from Arduino.
         if demo==0:
            pointer=open(serialport,"rb",2)
            mybyte=str(pointer.read(1))
            pointer.close()
            # Convert to a decimal value.
            grab=ord(mybyte)
         # Convert to 4 bit depth.
         plot=int(grab/16)
         # Invert to suit the text display window.
         plot=15-plot
         if plot<=0: plot=0
         if plot>=15: plot=15
         # Set up the plot position per grab.
         position=79+horiz+plot*79
         LoggerWindow=open(savefile,"rb+")
         LoggerWindow.seek(position)
         LoggerWindow.write("o")
         # Now get the whole array.
         LoggerWindow.seek(0)
         LoggerScreen=LoggerWindow.read(1659)
         # End of screen array update per plot.
         # Wait for a period for none AMIGA platforms.
         if sys.platform!="amiga": time.sleep(pause)
         # time.sleep() does NOT work on an A1200, WinUAE and E-UAE so pause......
            pausestring=str(pause)
            os.system("C:Wait "+pausestring)
            # ......and then do a clear screen.
            print "\f",
         # Do a clear screen for other platforms.
         # Now print the whole on screen...
         print LoggerScreen+"Real 8 bit decimal value is "+str(grab)+"; displayed 4 bit decimal value is "+str(15-plot)+"..."
         horiz=horiz+1
   while 1:
      # Set up DataLogger screen, use "\r\n" to suit Windows, "\r" is *ignored* on Linux and AMIGA_OS.
      # This is for the default Command Prompt, (Windows), Terminal, (Linux) and CLI, (AMIGA), modes.
      LoggerScreen="+-------+-------+-------+-------+-------+-------+-------+--------+ +--------+\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | |>(R)UN  |\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | +--------+\r\n"
      LoggerScreen=LoggerScreen+"+-------+-------+-------+-------+-------+-------+-------+--------+ | Ctrl-C |\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | | (K)B   |\r\n"
      LoggerScreen=LoggerScreen+"+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-+-++ +--------+\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | | (S)LOW |\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | +---------\r\n"
      LoggerScreen=LoggerScreen+"+-------+-------+-------+-------+-------+-------+-------+--------+ +--------+\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | | 1(0)S  |\r\n"
      LoggerScreen=LoggerScreen+"|       |       |       |       +       |       |       |        | |>(1)S   |\r\n"
      LoggerScreen=LoggerScreen+"+----------------------------------------------------------------+ +--------+\r\n"
      LoggerScreen=LoggerScreen+"| Status:- Running in DEMO mode.                                 | | (U)NCAL|\r\n"
      # Save the startscreen to write to.
      startscreen()
      savescreen()
      clrscn()
      print LoggerScreen
      doplot()
main()
# DataLogger program end.
# Enjoy finding simple solutions to often very difficult problems.
73...
Team AMIGA...
Bazza
