Video capture
Video capture
Postby kgolding » Sat Oct 15, 2005 8:52 pm
I'm after recommendations for a linux friendly video capture card or USB adapter to work with a standard composite video signal as provided by a CCTV camera.
Also any advice of software to enable time lapse recording, ideally only when movement is detected in the picture and a means of presenting the image within a web page.
Regards,
Kevin.
kgolding
RE: Video capture
Postby linuxgirlie » Sat Oct 15, 2005 9:21 pm
zoneminder is good but not perfect!!
linuxgirlie
RE: Video capture
Postby hopelessrobbie » Sat Apr 15, 2006 11:55 pm
i use a kworld bt878 tv/radio card and it works fine.
hopelessrobbie
RE: Video capture
Postby hopelessrobbie » Sat Apr 15, 2006 11:56 pm
most cards work you just need to know your tuner type
hopelessrobbie
