Another Python Freebie Based On MikeTron...
Postby Bazza » Thu Jun 02, 2011 5:56 pm
Hi all...
A DEMO to show how to plot XY inside a standard text mode Python
install. MikeTron gave me the idea of making this into a dreadful game.
It is primarily to show, using an INKEY$ idea for keyboard control,
how to plot characters inside a Python shell.
It is assumed that the shell is defaulting at 80 x 24 and Python is 2.6.x
or greater although it may work in earlier versions.
The INKEY$ function is not perfect but works reasonably well considering
Python is not able to do this by default.
I take no credit for this function and the pointer to the original is inside
the code. I do take credit for the plotting method though and shows
that Python can still do things without all the glitz added.
This plotting method is going to be used in a serious project I have in
mind.
Enjoy finding simple solutions to often very difficult problems...
Read the code for more information.
# SimpleTron2x.py
# Yes I know it is not much of a game but it is intended to show how to
# "draw", AND, to use the keyboard to "draw" inside a standard text mode
# Python shell.
# Written in such a way as to easily understand how it works.
# IMPORTANT NOTE!!! This ASSUMES a standard 80 x 24 shell window.
# This working idea is copyright, (C)2011, B.Walker, G0LCU.
# NOW issued as Public Domain to LXF...
# To run at the prompt...
# >>> execfile("/full/path/to/SimpleTron2x.py")
def main():
   import os
   import sys
   import termios
   import tty
   import random
   # A basic clear screen and cursor removal for program start...
   os.system("clear")
   os.system("setterm -cursor off")
   # Make any variables global just for this DEMO "game"...
   global screen_array
   global character
   global line
   global position
   global remember_attributes
   global plot
   global inkey_buffer
   global score
   screen_array="*"
   character="a"
   remember_attributes="(C)2011, B.Walker, G0LCU."
   line=1
   position=0
   plot=int(random.random()*4)
   inkey_buffer=0
   score=0
   # This is a working function; something akin to the BASIC INKEY$ function...
   # Reference:- http://code.activestate.com/recipes/134892-getch-like-unbuffered-character-reading-from-stdin/
   # Many thanks to Danny Yoo for the above code, modified to suit this program...
   # In THIS FUNCTION some special keys do a "break" similar to the "Esc" key inside the program.
   # Be aware of this...
   # An inkey_buffer value of 0, zero, generates a "" character and carries on instead of waiting for
   # a valid ASCII key press.
   def inkey():
      fd=sys.stdin.fileno()
      remember_attributes=termios.tcgetattr(fd)
      tty.setraw(sys.stdin.fileno())
      character=sys.stdin.read(inkey_buffer)
      termios.tcsetattr(fd, termios.TCSADRAIN, remember_attributes)
      return character
   # The welcome screen.
   print ""
   print "SimpleTron2x.py. A simple, odd style, Tron(ish) game."
   print "Another DEMO 2D animation for Linux platforms."
   print ""
   print "You control a vehicle leaving a trail behind it."
   print ""
   print "It is NOT always moving, and if it crosses any part"
   print "of the trail or border, (* characters), the game"
   print "is over. It CAN randomly move further than the key"
   print "presses so do not assume there is a bug... :)"
   print "Use the Q and A keys to change the direction to"
   print "up and down, and O and P for left and right."
   print "See how long you can survive! Score at the end."
   print ""
   character=raw_input("Hit <RETURN/ENTER> to begin... ")
   # Generate the game window as a single text string.
   # This assumes a standard 80x24 terminal text window.
   # Top line.
   while position<=78:
      screen_array=screen_array+"*"
      position=position+1
   # Next 20 lines.
   while line<=20:
      position=1
      while position<=78:
         screen_array=screen_array+" "
         position=position+1
      line=line+1
   # Bottom line.
   position=0
   while position<=78:
      position=position+1
   # Store the complete string for future use.
   gamefile=open("/tmp/TronArray","w+")
   gamefile.write(screen_array)
   gamefile.close()
   # End of game setup...
   # Start of game proper, set the initial position.
   position=(int(random.random()*60)+890)
   while 1:
      # Standard clear the terminal window.
      os.system("clear")
      print screen_array
      # Add another * when inkey_buffer=0.
      inkey_buffer=int(random.random()*2)
      # Use the INKEY$ function to grab an ASCII key.
      character=inkey()
      if character=="a": plot=0
      if character=="A": plot=0
      if character=="q": plot=1
      if character=="Q": plot=1
      if character=="o": plot=2
      if character=="O": plot=2
      if character=="p": plot=3
      if character=="P": plot=3
      # Esc key to exit the loop...
      if character==chr(27): break
      if plot==0: position=position+80
      if plot==1: position=position-80
      if plot==2: position=position-1
      if plot==3: position=position+1
      if position>=1759: position=1759
      if position<=0: position=0
      gamefile=open("/tmp/TronArray","r+")
      # Check for a * character in the array and......
      gamefile.seek(position)
      if gamefile.read(1)=="*":
         # ......exit if one exists at that point.
         gamefile.close()
         print "Game Over! You scored",score,"\b..."
         break
      gamefile.write("*")
      # Now get the whole array.
      gamefile.seek(0)
      screen_array=gamefile.read(1760)
      gamefile.close()
      # End of screen_array update per plot.
      score=score+1
   # Reset the cursor, etc...
   os.system("setterm -cursor on")
   character=raw_input("Have another game? (Y/N):- ")
   if character=="y": main()
   if character=="Y": main()
   if character=="": main()
main()
# SimpleTron2x.py end of game.
# Enjoy finding simple solutions to often very difficult questions.
73...
Team AMIGA...
Bazza
