Robert109
Joined: Wed Mar 09, 2011 9:21 am Posts: 65 Location: fife,scotland
Posted: Wed May 25, 2011 3:54 pm Post subject: low profile single slot graphics card |
| can any suggest a single slot low profile graphics card not after a huge performce.... Its for a secret build I wanna show off...just a tad to low for your standard grpahics cards...plus the motherboard I have is intel based running a i3 3.1 ghz 2100 sandy bridge cpu and I kno linux has a few problems with intel graphics so I thought if I can get my hands on low profile graphics card by nvidia ill have better luck running a duel boot...I really cant wait to show you guys my custome case..nothing tacky with silly lights.. |
bobthebob1234 LXF regular
Joined: Thu Jan 03, 2008 9:38 pm Posts: 1356 Location: A hole in a field
Posted: Wed May 25, 2011 4:17 pm Post subject: |
Well its not very secret now...
I haven't used any low profile graphics cards personally, but I know they do exist. You usually get a full height card with a low profile 'front' (?? Is that what it is called? Don't know. The metal bit (shield?) at the front ) that you can fit. _________________ For certain you have to be lost to find the places that can't be found. Elseways, everyone would know where it was |
Robert109
Posted: Wed May 25, 2011 11:48 pm Post subject: |
I kno gave some of the secret up lol...low profile as in height...the case Iv got made is 96mm (h) 222mm (w) 328(d)
the mother board I have is h67m-itx that I got from a friend and says he had some trouble with linux and the on board graphic so he bought a basic graphics card and it worked fine.
The case Im geting custome made will be out of steel and alu by the same friend at college whos doing metal work so this is part of his course...I supplied the design I kno this is a small itx case but will look nice with plenty of air flow..I wished I could upload some pics of my design to show you guys..in a few weeks ill make utube vid and post up the link |
lok1950 LXF regular
Joined: Tue May 31, 2005 6:31 am Posts: 958 Location: Ottawa
Posted: Thu May 26, 2011 12:10 am Post subject: |
Have a look here You might save your self some cash as for the possible problems check this
Enjoy the Choice  |
