IceWM and the little black window startup problem
Postby Farcry » Wed May 18, 2011 9:43 pm
Firstly, I'm ashamed to say it has taken me since LXF 103 to pursue Mike Saunders's strong recommendation to try IceWM. But he's so right and it is a cracking little window manager (even doing tiling as well!).
Next, there is one irritating problem with IceWM which does seem to be a timing/race bug (in icewmtray?) going back ages (eg see ... tid=100031). It's also been reported in the Arch Linux forums at and
What happens is that every so often the programs in the startup file get loaded, but their icons don't appear in the system tray. Instead a little indestructible black window appears. On restarting X, it always seems to correct itself. (For me it seems to happen after a power-on.)
The solution from the second Arch thread above is to put a "sleep 1" before every command in the startup file which puts an icon in the system tray. For example:
sleep 1; parcellite &
sleep 1; xpad -N &
sleep 1; nm-applet --sm-disable &
sleep 1; trayclock &
sleep 1; conky &
However, I've actually found it better to create an additional script (say, called sleepy) and call it at the end of startup thus:
sleep 4 && ${0%/*}/sleepy &
Every program that puts an icon in the system tray is called in sleepy, without any other sleeps being required.
Hope this might help someone else who is frustrated by such a silly problem in an otherwise excellent piece of software.
Mike - have you encountered this and come up with a better solution?!
Return to Hints and tips
