Quickly and easily changing screen resolution to one...
Postby bobthebob1234 » Thu Apr 21, 2011 8:53 pm
not recognised automagically.
Run
cvt X Y
Replace X & Y with the values you want.
This will produce something like
# 1440x900 59.89 Hz (CVT 1.30MA) hsync: 55.93 kHz; pclk: 106.50 MHz
Modeline "1440x900_60.00"  106.50  1440 1528 1672 1904  900 903 909 934 -hsync +vsync
Then add a new mode using xrandr
xrandr --newmode big 106.50 1440 1528 1672 1904 900 903 909 934
Replace big with what ever you want and the numbers to that of the output of cvt
Now add the the mode to your output.
xrandr --addmode VGA-1 big
VGA-1 might be different, type xrandr --output and then press tab twice and you will get a list of outputs
Now make that output use the mode
xrandr --output VGA-1 --mode big
With a bit of voodoo chanting you should now have the new resolution.
Note that this is a quick and dirty way of changing to a custom resolution, and after a reboot the resolution will go back to the old one.
If you screw up just reboot and the resolution should go back to normal.
bobthebob1234
Return to Hints and tips
