how to find parameters that a kernel module takes
Post new topic   Reply to topic    Linux Format forums Forum Index -> Hints and tips
John Lumby
PostPosted: Sat Apr 16, 2011 1:45 am    Post subject: how to find parameters that a kernel module takes Reply with quote
Suppose you have some vague idea that some kernel module may take some parameter telling it what to do, but can't find out what the parameter is. Many device drivers have such parms. Or suppose you are plain curious. Then you can run this nifty scriptlet to list the parms and their documentation strings :
Suppose the module name is abcxyz
kmod="abcxyz";find /lib/modules/`uname -r`/kernel -name ${kmod}.ko -exec strings -a '{}' \; | fgrep -e parm=
Three caveats:
1) the module must exist under the /lib/modules dir - i.e. it must not be built-in to the kernel image
2) you have to spell the name exactly - hyphen and underscore are not interchangeable, as the scriptlet is looking for a matching file. But you can run it again with the alternative, or you can make the find command cleverer for a specific name, e.g. to look for whichever of parport_pc or parport-pc
find /lib/modules/`uname -r`/kernel -name parport'[-_]'pc.ko -exec strings -a '{}' \; | fgrep -e parm=
parm=init_mode:Initialise mode for VIA VT8231 port (spp, ps2, epp, ecp or ecpepp)
parm=dma:DMA channel
parm=irq:IRQ line
parm=io_hi:Base I/O address (ECR)
parm=io:Base I/O address (SPP regs)
3) some modules parms may be hidden if the kernel was configured to omit the relevant feature, as they will be compiled out.
John Lumby
PostPosted: Sun Apr 17, 2011 5:30 pm    Post subject: Reply with quote
You can also get a list of parameters with
Code:
modinfo modulename
Post new topic   Reply to topic    Linux Format forums Forum Index -> Hints and tips All times are GMT
