A standard Python 2.6+ LF Audio Oscilloscope.
Postby Bazza » Wed Apr 06, 2011 9:41 pm
Hi all...
I think this may well be a first for both Python and LXF.
I am building a kids level seismometer and wanted to use standard Python
inside Linux.
This DEMO code was my starter idea and looks as though using standard
ASCII only might just work a real treat.
I've issued it to LXF under the MIT licence for future reasons.
It doesn't look much on screen except that the waveform(s) shown is/are a
crude electrical representation of your voice. ;o)
It is possible to link the earphone socket on this notebook to the mic
input and start the Audio Function Generator, elsewhere in this forum,
in a separate Python terminal and see those waveforms inside the
AudioScope.py`s own Python terminal.
Enjoy finding simple solutions to often very difficult problems.
Be aware of wordwrapping, etc...
# AudioScope.py
# DEMO LF Audio Oscilloscope using /dev/dsp inside Linux.
# Original copyright, (C)2011, B.Walker, G0LCU.
# Issued to LXF under the MIT licence.
# The timebase runs vertically and the waveform amplitude horizontally.
# It grabs a sample for about 1 second and displays the results AFTER
# the sample; technically a basic LF Storage Audio Oscilloscope.
# The display only uses standard ASCII characters.
# To run just type from the prompt ">>>"...
# >>> execfile("/full/path/to/AudioScope.py")<RETURN/ENTER>
# Tested on Python 2.6.x only but should work on other versions of 2.x.x.
# Ensure /dev/dsp exists; if not install oss-compat from your distro`s
# repository. Also ensure the sound card is not already in use.
# Enjoy finding simple solutions to often very difficult problems... ;o)
# If you are just trying this out and have an internal mic, just talk
# loudly into the microphone and see your vocal wavefrom on screen...
# Needless to say using the external microphone input as an input this
# becomes a single channel uncalibrated LF Audio Oscilloscope.
# Press Ctrl-C to STOP.
# Import any necessary modules.
import os
# Do a basic screen clear.
# Turn the cursor off to look prettier... ;o)
os.system("setterm -cursor off")
def main():
   # Set special variables global.
   global audioscope
   global chardisplay
   global offset
   global timebase
   global record
   # Known variables.
   audioscope = 0
   chardisplay = "(C)2011, B.Walker, G0LCU."
   offset = 0
   timebase = 1
   record = "Initial issue to LXF under the MIT licence"
   # Throw away local variables.
   n = 0
   while 1:
      # Sample the microphone/external_microphone_input for approximately 1 second.
      audio = file('/dev/dsp', 'rb')
      record = audio.read(8192)
      # This value points to a character in the 8192 byte string.
      # "offset" can be any value from 0 to 191.
      offset = 0
      # Start the loop from character at position 0.
      while offset <= 8191:
         # Convert the character to a decimal number.
         audioscope = ord(record[offset])
         # Now convert to 6 bit depth to fit one terminal line.
         audioscope = int(audioscope/4)
         # This should never occur but don`t allow an error.
         if audioscope >= 63: audioscope = 63
         if audioscope <= 0: audioscope = 0
         # Invert to correct the trace shown.
         audioscope = 63 - audioscope
         # Loop count to get the correct position to print the plot.
         n = 0
         # Set the trace position for each line and......
         chardisplay = "       "
         while n <= audioscope:
            # ......add the required spaces until completed then......
            chardisplay = chardisplay + " "
            n = n + 1
         # ......print the plot point using *.
         print chardisplay + "*"
         # Point to the next character to character in the 8192 string.
         # "timebase" can be any value from 1 to 360.
         offset = offset + timebase
   # Assuming a Ctrl-C arrives here enable the cursor again.
# End of DEMO.
Team AMIGA...
