gonna ask a really stupid question hdmi,dvi,vga
Postby Robert109 » Sun Apr 03, 2011 10:48 am
Oki I was doing some research on my pc monitor and it has 1028x1024 but its a vga connection even thou in the website it says its a dvi.
any way I was wondering if I bought a hdmi to dvi and got a dvi to vga adapter would it work or am I just a silly t*t
I did see this and if Im reading this rite it will work
http://www.amazon.co.uk/HDMI-Male-SVGA- ... 260&sr=1-4
Robert109
Postby ollie » Sun Apr 03, 2011 11:35 am
If your graphics card is outputting through the VGA connection you on't achieve anything by trying to use HDMI. The VGA output to your monitor, which I'm sure is actually 1280 x 1024 if it is the standard LCD 4:3 format, outputs sufficient quality for the monitor.
Postby Robert109 » Sun Apr 03, 2011 11:37 am
sorry I should have said this is to input another device that is hd thru the moniter and your correct its 1280x1024
Robert109
Postby optimizer » Mon May 02, 2011 8:17 pm
Sort of a related question:
I am trying to find the best resolution when I stream from my laptop to my Hi Def flat screen TV.
I have been using the VGA cable but am not happy with the results.
My laptop is an older model with no HDMI output.
Can anyone suggest an add-on solution? ( I surely do not want to do anything at the board level since those are so delicate.)
optimizer
Return to Off Topic
