deane
Posted: Mon Mar 07, 2011 6:34 pm Post subject: Touchscreen (wacom) and Debian |
I quite like my HP tm2 laptop - I had problems for ages with it getting hot, but after finally working out how to get the vgaswitcheroo to work in debian (mainly it was a case of putting the kernel modesetting variables in different places for both sets of drivers and then actually *loading* the damned drivers!) it runs rather cool now - cooler than windows 7, in fact.
Now I can almost abandon windows for regular use, except when using it as a touchscreen laptop.
Yes, the touchscreen works fine, but it lacks the finesse that the windows setup has. Touching it immediately classes as a tap, so there's no drag-scrolling. It's also not possible to right click by pressing and holding or pressing and right tapping.
I'm assuming there must be a set of variables somewhere in a config file for the X side of the wacom drivers, and possibly some add-on software the make the experience a little more polished?
Oh, and don't suggest going to Ubuntu - I've tried numerous recent versions and just prefer Debian. |
Dutch_Master LXF regular
Posted: Mon Mar 07, 2011 7:12 pm Post subject: |
You are aware that X doesn't support multi-touch events, are you?
As for the "touch = click" issue, did you try and change the repeat-delay settings? (how much time between to touch-events to be seen as separate taps) |
deane
Posted: Mon Mar 07, 2011 8:46 pm Post subject: |
| I wasn't aware that X couldn't do multitouch, but the X config file settings look promising. |
deane
Posted: Mon Mar 07, 2011 10:18 pm Post subject: |
I've tried to tweak my xorg.conf, but it appears that my system is using /usr/share/X11/xorg.conf.d and contains 20-wacom.conf as below:
| Code: |
Section "InputClass"
Identifier "Wacom class"
# WALTOP needs a patched kernel driver, that isn't in mainline lk yet,
# so for now just let it fall through and be picked up by evdev instead.
# MatchProduct "Wacom|WALTOP|WACOM"
MatchProduct "Wacom|WACOM"
MatchDevicePath "/dev/input/event*"
Driver "wacom"
EndSection
Identifier "Wacom serial class"
MatchProduct "Serial Wacom Tablet"
Driver "wacom"
Option "ForceDevice" "ISDV4"
EndSection
Identifier "Wacom serial class identifiers"
MatchProduct "WACf|FUJ02e5|FUJ02e7"
Driver "wacom"
EndSection
# N-Trig Duosense Electromagnetic Digitizer
Identifier "Wacom N-Trig class"
MatchProduct "HID 1b96:0001|N-Trig Pen"
Driver "wacom"
Option "Button2" "3"
EndSection |
trying:
xsetwacom set "touch" Gesture "on"
doesn't work, because my device appears as 'Finger' though referring to it with that also doesn't work, but I have tried with the ID number.
I can only assume that something like the following needs to go in somewhere, but not sure whether I should be creating an xorg.conf in /etc/X11 or what:
| Code: | # This section is for the TabletPC that supports touch
Section "InputDevice"
Driver "wacom"
Identifier "touch"
Option "Device" "/dev/ttyS0" # SERIAL ONLY
Option "Type" "touch"
#Option "ForceDevice" "ISDV4" # Tablet PC ONLY
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "stylus" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
InputDevice "touch" "SendCoreEvents"
EndSection
The results of xinput list:
| Code: |
⎡ Virtual core pointer id=2 [master pointer (3)]
⎜ ↳ Virtual core XTEST pointer id=4 [slave pointer (2)]
⎜ ↳ Wacom ISDv4 E3 Finger id=11 [slave pointer (2)]
⎜ ↳ Wacom ISDv4 E3 Pen eraser id=12 [slave pointer (2)]
⎜ ↳ Wacom ISDv4 E3 Pen id=13 [slave pointer (2)]
⎜ ↳ Wireless Keyboard/Mouse id=15 [slave pointer (2)]
⎜ ↳ PIXART USB OPTICAL MOUSE id=16 [slave pointer (2)]
⎜ ↳ SynPS/2 Synaptics TouchPad id=19 [slave pointer (2)]
⎣ Virtual core keyboard id=3 [master keyboard (2)]
↳ Virtual core XTEST keyboard id=5 [slave keyboard (3)]
↳ Power Button id=6 [slave keyboard (3)]
↳ Video Bus id=7 [slave keyboard (3)]
↳ Video Bus id=8 [slave keyboard (3)]
↳ Power Button id=9 [slave keyboard (3)]
↳ Sleep Button id=10 [slave keyboard (3)]
↳ Wireless Keyboard/Mouse id=14 [slave keyboard (3)]
↳ HP Webcam id=17 [slave keyboard (3)]
↳ AT Translated Set 2 keyboard id=18 [slave keyboard (3)]
↳ HP WMI hotkeys id=20 [slave keyboard (3)]
↳ ACPI Virtual Keyboard Device id=21 [slave keyboard (3)]
Attempting to set gesture:
| Code: |
xsetwacom set 11 Gesture "on"
Property 'Wacom Enable Touch Gesture' does not exist on device.
So not really sure what to do now... |
nelz Moderator
Posted: Tue Mar 08, 2011 1:19 am Post subject: |
xorg.conf.d is replacing xorg.conf. Instead of one monolithic file with hundreds of settings, you now have a separate file for each section of the settings. The effect is exactly the same, but it is simpler to manage. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
