heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1795 Location: Cheshire, UK
Posted: Tue Jan 04, 2011 12:42 am Post subject: iOdd - nice piece of kit |
Just got this email from the nice guy who runs Chester LUG. Thought it might appeal to some people...
I've found a handy little device to save burning off endless ISOs of the latest distros. It's called the i-Odd (yes another 'i' device) and it works very simply. It's a USB HDD enclosure that you add a 2.5" SATA drive. It appears as a USB drive and you copy all of your ISOs into a _iso directory. Using the small menu on the device you select an ISO file and it then appears as a USB CDROM on your system. I got one a couple of weeks ago and it's been very handy already.
I got mine from Linitx - http://linitx.com/viewproduct.php?prodid=12726
Les |
dandnsmith LXF regular
Joined: Fri Apr 15, 2005 11:01 am Posts: 267 Location: Berks, UK
Posted: Tue Jan 04, 2011 6:41 am Post subject: |
Whether this is a good thing is very much a personal choice.
For me, it looks like a gadget which I don't need, at a higher price than I would pay - compare it with using CDRs, when it would buy an awful lot, or CDRW, when you don't get quite as many, but less waste. I can see a time saving - but this is often covered by thinking about or doing something else, so is largely illusory. _________________ Derek |
heiowge LXF regular
Posted: Tue Jan 04, 2011 9:58 am Post subject: |
I think it's great. I don't have a laptop, but do have a netbook. No CD drive.
Saying that, I can see what you mean about overpriced for what it does. It'd be far better if it just had a USB female socket and SD card slot and no 2.5" drive enclosure. I can't see anyone needing 500 GB of ISO files stored. An 8Gb flash drive would do nicely. It'd be far easier than setting up a live disc on a flash drive every time. Especially if you were testing several. Just stick the ISOs on a common flash drive, plug in and off you go... |
nelz Moderator
Posted: Tue Jan 04, 2011 1:39 pm Post subject: |
At first sight, I don't see why this can't be done in software. an autobooted program on the USB device should be able to do all of this, at no cost beyond a USB flash drive. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
PCNetSpec LXF regular
Joined: Sun Feb 21, 2010 3:50 pm Posts: 623 Location: Cornwall UK
ollie Moderator
Posted: Wed Jan 05, 2011 8:10 am Post subject: |
All the time, I have a couple of USB thumb drives that I multiboot for a couple of different things. It's great but disappointing that you need windows to set up and add ISO images.  |
