leke LXF regular
Joined: Mon Oct 22, 2007 6:45 pm Posts: 479 Location: Oulu, Finland
Posted: Fri Dec 17, 2010 9:03 am Post subject: Updating the desktop icon in python |
Hi, the following code works fine -- that is it creates the icon and support text in the same location as the python script, but doesn't update the desktop icon correctly. Specifically, this function doesn't seem to work. | Code: | def update_icon_file():
cmd = "xdg-desktop-icon install --novendor /home/asdf/Desktop/test.desktop"
os.system(cmd)
If I run xdg-desktop-icon install --novendor /home/asdf/Desktop/test.desktop in the terminal though, it works fine.
| Code: | #!usr/bin/env python
# -*- coding: utf-8 -*-
import feedparser, os, re
#### Update the icon on the desktop - Change test.desktop to the name of your icon file.
os.system(cmd)
#### End.
#### Store of details for icon config file
def config_file_succsess():
success = '''#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Name = {0}
GenericName = info icon
Comment = info icon created by http://rebol.vlexo.net
Exec = python /home/asdf/Dev/python/info_icons/icon_weather.py
Terminal = false
Type = Application
Icon = {1}
Categories = Application
MimeType = image/jpeg;text/python;
StartupNotify = false
'''.format(rss_feed_summary + "\\n" + rss_feed_time, icon_image) # {0}, {1}, etc...
f = open('/home/asdf/Dev/python/info_icons/test.desktop','w') # need to find how to get ls of location of python script.
f.write(success)
f.close()
update_icon_file()
def config_file_fail():
failed = '''#!/usr/bin/env xdg-open
[Desktop Entry]
Version=1.0
Name = {0}
Terminal = false
Type = Application
Icon = /home/asdf/Dev/python/info_icons/icons/icon-mystery.jpg
'''.format(connect_error)
f.write(failed)
f.close()
update_icon_file()
#### End.
#### Get some RSS data from server
def write_it():
global rss_feed_summary, rss_feed_time, connect_error
try:
df = feedparser.parse('http://www.rssweather.com/wx/fi/pirkkala/rss.php')
rss_feed_summary = str(df.entries[0].summary)
rss_feed_time = str(df.entries[0].updated)
which_icon()
except:
connect_error = "Could not retrieve data from server."
config_file_fail()
def which_icon():
global icon_image, s, temp
# Search for a word or number in string <line1>
s = rss_feed_summary.lower() # all lowercase
temp = s.split() # split by space
temp = temp[0][:-1] # trim the 'c' from temperature
temp = int(temp) # convert string to integer
if ("fog" or "mist") in s:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-fog.jpg"
elif "rain" in s:
if not "grains" in s:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-rain.jpg"
elif "rain" in s:
elif ("wind" or "gale") in s:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-wind"
elif temp > 0:
if temp < 10:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-cold.jpg"
elif temp < -25:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-hibernate.gif"
elif temp < 0:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-winter.jpg"
elif temp > 30:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-fire.jpg"
elif temp > 20:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-summer.jpg"
else:
icon_image = "/home/asdf/Dev/python/info_icons/icons/icon-mystery.jpg"
write_it()
#### End.
_________________ I codes here: http://notsure.tk |
nelz Moderator
Posted: Fri Dec 17, 2010 9:42 am Post subject: |
This is probably to do with the execution environment, when you run it from a terminal, you have sourced .bashrc.
The trouble with os.system() is it just sends the command to the system and forgets about it, so you get no return codes or error messages, try using the subprocess module instead. _________________ Unix is user-friendly. It's just very selective about who it's friends are. |
leke LXF regular
Posted: Fri Dec 17, 2010 12:22 pm Post subject: |
| nelz wrote: | This is probably to do with the execution environment, when you run it from a terminal, you have sourced .bashrc.
The trouble with os.system() is it just sends the command to the system and forgets about it, so you get no return codes or error messages, try using the subprocess module instead. | Thanks, I never knew about that. Just reading up on it now. _________________ I codes here: http://notsure.tk |
