kits
Postby Rhakios » Sat Nov 13, 2010 7:32 pm
On the subject of motherboards, I suppose it's worthwhile finding out if the manufacturer supports OS-independent BIOS updates.
Postby heiowge » Fri Feb 18, 2011 6:19 pm
Update....
I sacked off the idea of a self build. I simply don't have the time. I do, however, have a £400 build budget, which is higher than I expected. After supplying my requirements (lower RAM and hd, to boost processor and max RAM, etc.), this is what the local fellow came up with:
Intel Q8300 CORE2QUAD 2.5 GHZ 4mb Cache
ASRock P45 Motherboard (16gb Total DDR3/6 SATA Ports/ 6Rear USB +3 Front Panel)
4GB DDR3 1333mhz
250GB Sata HDD
DVD-RW
Front Mounted Card Reader
Nvidia GT430 1GB PCI-E Graphics Card
ATX Case 450w PSU
£395 built and ready to go...
Opinions?
Postby ollie » Sat Feb 19, 2011 8:23 am
heiowge wrote:Intel Q8300 CORE2QUAD 2.5 GHZ 4mb Cache
4GB DDR3 1333mhz
250GB Sata HDD
DVD-RW
ATX Case 450w PSU
Opinions?
Can they offer a more up to date CPU? i5 Quad Core or i7? The Q8300 is 2 years old now. An i7 has an effective 8 CPUs because of hyperthreading which isn't available in the older CPUs. It will also need a motherboard update for the newer CPU socket but this also allows for CPU updates, whereas the older socket doesn't support the newer CPU.
Postby heiowge » Sat Feb 19, 2011 9:13 am
I'll have to ask. Maybe not on my budget. Plus I need at least one IDE socket. Maybe a more up to date motherboard doesn't have one...
Postby heiowge » Sat Feb 19, 2011 9:54 am
I've asked him about a faster processor. I'm also upgrading to a 500GB hd for an extra £6. :D
****edit****
While I was typing that, he sent me this...
The top processor for that board that I can get is the next model up from that, the Q8400- 2.66ghz / 4mb cache, that would add about £11 to the total.... beyond that you’re getting up into intel’s I range (i3/5/7) which would require a different board and I don’t know how they handle unix systems....
Postby heiowge » Sat Feb 19, 2011 11:32 am
Update... He replied to my quote for i processor spec...
To build a comparable system using ‘I’ Processors would be as follows:
ASROCK H55 S1156 DDR3 GbE DVI/HDMI XFIRE
4GB DDR3 1333mhz
500GB Sata HDD
DVD-RW
ATX Case 500w PSU
Intel i3 3.2Ghz Dual Core 4mb Cache : £395
Intel i5 2.8Ghz Quad Core 8mb Cahce: £469
I can afford i3, I may be able to stretch to i5. Any compatability issues? Thoughts on my option? I|s the i3 better than the last spec pc?
Postby nordle » Sat Feb 19, 2011 6:35 pm
Sandy Bridge is out...ish, you have to make sure you get a de-bugged chipset.
But for the price, the 2.8 i5 quoted by your contact is going to take some beating.
As for compatibility, there are a few H55 mobo's in the Asrock range:
http://www.asrock.com/microsite/IntelH5 ... p?c=Models
I think, therefore I compile
nordle
Postby Marrea » Sat Feb 19, 2011 9:55 pm
heiowge wrote:I can afford i3, I may be able to stretch to i5. Any compatability issues?
My main desktop, which I bought last May, has an Asus P7H55D-M Pro motherboard with an Intel Core i5 650 3.20 GHz CPU. I’m running Ubuntu 10.04 64 bit on it and haven’t come across any compatibility problems as yet.
Marrea
Postby heiowge » Mon Feb 21, 2011 10:22 am
Opening up AMD as an option, he offers:
PHENOM II X4 955 SKT AM3 3.2GHZ BLK ED
4Gb DDR3
ASRock M3A 770de (16gb Ram/ 4x sata/ 4x usb rear)
500gb sata hdd
DVD-RW
Card Reader
Nvidia GT430 1GB Graphics
Case + 500w PSU
£399
Or... for £455
PHENOM II X6 1090t SKT AM3 3.2GHZ BLK ED
4Gb DDR3
500gb sata hdd
DVD-RW
Card Reader
Case + 500w PSU
Opinions?
Postby Rhakios » Mon Feb 21, 2011 10:44 am
heiowge wrote:Opinions?
I want one!
Postby nelz » Mon Feb 21, 2011 10:58 am
I want one!
An opinion? You have plenty of those already :P
Postby heiowge » Mon Feb 21, 2011 11:40 am
What I mean is that I can stretch the budget. What should I get? The i5 box or the Phenom II X6 one?
Postby PCNetSpec » Mon Feb 21, 2011 1:33 pm
In my opinion...
AMD Phenom II X6 1090T, every time :)
As well as the extra cores (i5-2300 doesn't have hyperthreading), it's Average CPU Mark (according to PassMark) is higher -
AMD Phenom II X6 1090T = 6043
Intel core i5-2300 @ 2.8ghz = 5351
These scores are only for comparison, and are fairly meaningless unless taken in context.
Not to mention as it's a Black Edition, it's an overclockers dream.
Linux in the UK
The Linux Community Forum
PCNetSpec
Postby heiowge » Mon Feb 21, 2011 1:51 pm
Your thoughts reflect mine and another friend of mine in the know. So I've ordered the Phenom II X6 PC. :D
Postby PCNetSpec » Mon Feb 21, 2011 1:59 pm
Lucky git ;) .. Can I borrow it, just for testing purposes? .. I promise I'll give it back ;)
Linux in the UK
PCNetSpec
PreviousNext
