Wii USB
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic
PostPosted: Thu Oct 28, 2010 11:56 am    Post subject: Wii USB Reply with quote
Ok, I have a USB charger question...
I have a Kodak camera with USB charger (USB can charge from PC and there is also a plug converter so I can charge from mains). My wife has wii remote chargers that also charge from USB.
What I want to know is, can I use the same mains - USB plug with the Wii charger? They have the right sockets, but I'm just a little worried that the voltage (or something else electrical) is wrong and I might fry the charger, or worse, £70 worth of wii remotes.
PostPosted: Sun Oct 31, 2010 10:40 am    Post subject: Reply with quote
Technically there shouldn't be any problems. If you use a particular plug/socket for a connector you should meet the specifications for that standard.
Having said that, some manufacturers don't comply with the specifications. The most notable (spectacular) that I know of was a very well known supplier who doesn't have any commercial outlets. A number of years ago they used the ATX motherboard socket/plug combo but switched a 12V pairing. So, when people purchased a new ATX standard power supply the motherboards let lots of smoke out of components. Crying or Very sad
MartyBartfast
PostPosted: Sun Oct 31, 2010 11:48 am    Post subject: Reply with quote
I have several mains USB chargers, and countless USB devices and I happily interchange them all the time. I must admit that I've never even considered that there could be incompatibility.
The USB standard is 5v, and the charger you've got should have it's specs printed on it somewhere, so as long as it's a 5v output you should be fine.
AndyBaxman
PostPosted: Sun Oct 31, 2010 8:23 pm    Post subject: Reply with quote
A lot of USB chargers put out more than the 5v standard. The device they are associated with can cope with this and, indeed, may benefit from it (faster recharge). The device itself will charge from a standard USB socket (on a PC, Wii, etc) but not as fast.
The reverse may not be true. While it is safe to plug any USB chargeable device into a standard 5v USB socket, it is not safe to assume that the charger for a specific device is safe to use with another device.
Always check that the charger's output is 5v regulated DC before using it to charge something other than the device it was intended to charge.
PostPosted: Mon Nov 01, 2010 8:53 pm    Post subject: Reply with quote
Also, some USB chargers may struggle with a high current device.
For example, a friend used one to power an external disk drive, and it soon got very hot indeed, too hot to touch.
1slipperyfish
Forum Jester
PostPosted: Fri Nov 12, 2010 7:28 pm    Post subject: Reply with quote
yeah i have the same problem Very Happy i'm too hot to handle, too cold to hold Very Happy
paul
Bazza
PostPosted: Sat Nov 13, 2010 4:25 pm    Post subject: Reply with quote
Oi 1sf (troll)...
BO?
Oh, you are SOOO strong...
But smell ain`t everything... ;oD
73...
Team AMIGA...
1slipperyfish
Forum Jester
PostPosted: Sat Nov 13, 2010 5:48 pm    Post subject: Reply with quote
Bazza wrote:
Oi 1sf (troll) (troll)...
BO?
haha Laughing
paul
Post new topic   Reply to topic    Linux Format forums Forum Index -> Off Topic All times are GMT
