PHP Coding Academy Project 1
Postby NoNameWill » Mon Sep 20, 2010 10:57 pm
Hello,
I am getting this line in terminal when I run this script.
PHP Warning:  file_get_contents(output): failed to open stream: No such file or directory in /home/will/PHP/project1.php on line 22
There is a output file in PHP directory.
Here is what I have from following the instructions. I think I installed all the programs I need. I got them through SPM in Ubuntu 10.4.
I know I may have misinterpreted what was there. But I need some help. Thank you
<?php
function subdir_scan($dir){
    $files=scandir($dir);
    foreach($files as $file){
        if($file==".")continue;
        if($file=="..")continue;
        print "$dir/$file\n";
        if(is_dir("$dir/$file")){
            subdir_scan("$dir/$file");
chdir("..");
subdir_scan(".");
chdir("..");
ob_start();
subdir_scan(".");
$new_run=ob_get_clean();
$old_run=file_get_contents("output");
$new_array=explode("\n",$new_run);
$old_array=explode("\n",$old_run);
NoNameWill
Postby NoNameWill » Tue Sep 21, 2010 12:03 am
I have gotten to the end of project one but I am getting this now
PHP Warning:  file_put_contents(output): failed to open stream: Permission denied in /home/will/PHP/project1.php on line 36
With this script
<?php
chdir("..");
subdir_scan(".");
chdir("..");
ob_start();
subdir_scan(".");
if(file_exists("output")){
    $differences=array_diff($new_array,$old_array);
    foreach (differences as $file){
        echo "New file detected:$file\n";
file_put_contents("output",$new_run);
NoNameWill
Postby NoNameWill » Tue Sep 21, 2010 5:22 am
NoNameWill wrote:I have gotten to the end of project one but I am getting this now
With this script
<?php
chdir("..");
subdir_scan(".");
chdir("..");
ob_start();
subdir_scan(".");
    foreach ($differences as $file){
NoNameWill
Postby Ram » Tue Sep 21, 2010 7:55 am
Your scanning twice - have a look at this thread!!!
Postby NoNameWill » Tue Sep 21, 2010 3:57 pm
Now I see the error of my way. I did looked at that thread but it wasn't computing in my brain. Took a good nights rest to let it all set in.
Thank you for the help. Now off to figure out the challenge I am having in project 2. :D
NoNameWill
