PHP coding academy project 1
Postby dansit » Tue Jul 27, 2010 5:45 pm
Hi i have been going through the project 1 php academy book and have come across and experiencing problems! May be i am making a simple fault.
I have got to page 22 and all work well! Got the right output at the terminal. When i got to page 23 and added the extra code i start to get error's when running the script.
This was the page 23 code i added to the script.
chdir("..");
subdir_scan(".")
This is the complete code and error's.
<?php
function chdir("..");
   subdir_scan(".");
   subdir_scan($dir){
   $files = scandir($dir);
   foreach($files as $files){
      if ($files==".")continue;
      if ($files=="..")continue;
      print "$dir/$files\n";
      if (is_dir("$dir/$files")){
         subdir_scan("$dir/$files");
subdir_scan(".")
Error message.
PHP Parse error:  syntax error, unexpected T_CONSTANT_ENCAPSED_STRING, expecting '&' or T_VARIABLE in /home/username/php/project1.php on line 3
Any help in what i have done wrong would be great! I'm sure it's a simple mistake i've made but i have checked over and over again!
I am a simple newbie forgive me for not spotting the problem. :?
dansit
Postby Dutch_Master » Tue Jul 27, 2010 7:56 pm
Actually, the solution is part of the error mesage:
The clue is in the last part:
Now, look at your code, what's on line 3?
The PHP parser says it's invalid syntax. The question you now need to ask yourself is: "why is that invalid?" and go from there :)
Postby leke » Wed Jul 28, 2010 3:34 pm
Is it correct to put 'function' in front of chdir() -- an existing php function?
http://php.net/manual/en/function.chdir.php
leke
