Project 1 - PHP coding
Postby sirobert » Wed Jul 21, 2010 6:51 am
I'm attempting the first php project, but the output to buffer commands arn't working. The files are still output to the command line, nothing is written to the output file. What am I doing wrong?
Thanks
Simon
<?php
function subdir_scan($dir){
$files = scandir($dir);
foreach ($files as $file){
if($file==".") continue;
if($file=="..") continue;
print "$dir/$file\n";
if(is_dir("$dir/$file")){
subdir_scan("$dir/$file");
chdir("..");
ob_start;
subdir_scan(".");
$output=ob_get_clean();
echo $output;
file_put_contents("output",$output);
sirobert
Re: Project 1 - PHP coding
Postby bobthebob1234 » Wed Jul 21, 2010 7:31 am
sirobert wrote:nothing is written to the output file.
I assume you are talking about
Does the user you are running the script as have permission to write to the file 'output'?
If the file 'output' doesn't exist does the user have permission to create and write a file?
bobthebob1234
PHP Project 1
Postby sirobert » Wed Jul 21, 2010 9:57 am
yup, running the script as me and the owner and group is me. I think it might be something to do with the output buffer commands as the instructions say that the output to the screen should be suppressed if its going to the buffer.
Thanks
sirobert
