Coding Academy - Unexpected Error Msg.
Postby chriswadams » Wed Jun 23, 2010 9:05 pm
Hi, all--
I'm working on Project 2 of the Coding Academy (WordScramble), and I got an unexpected error message while doing Homework #3. The offending code is:
static string lines;
public static void Main (string[] args)
if (args.Length > 12){
string[] lines = File.ReadAllLines(args[1]);
else{
string[] lines = File.ReadAllLines("wordlist");
foreach(string word in lines){
and the error message for the last line is this:
Cannot convert type `char' to `string' (CS0030)
This problem didn't crop up until I began the 3rd homework assignment (ie. the code worked fine up to that point), so I assume I did something wrong there, but I can't figure out what it was. The variable 'word' is declared to be a string in the code I pasted above, and the variable 'lines' is an array, so why the compiler thinks they are 'char' and 'string' types, I have no idea. Any suggestions?
I can paste in the code for the rest of the program if that will be of any help.
Thanks,
chriswadams
chriswadams
Postby Ram » Thu Jun 24, 2010 12:17 am
Think I need to see the rest of your code.. I can't replicate the error using your code.
From your snippet, I don't see the need for this line.
However, before you paste your code, can I ask the logic on this snippet of code.
As I see it, you would need to launch the program with 14 arguments to read the second argument (args[1]). As in the above snippet.
This might help
Don't forget that counting begins at zero.
So to launch the program without any arguments do this
./wordscramble
To launch with 1 argument do this
./wordscramble mywordlist
mywordlist would then be stored in (args[0])
Re: Coding Academy - Unexpected Error Msg.
Postby chriswadams » Thu Jun 24, 2010 11:30 pm
Hi Ram--
This line:
[code]static string lines;[/code]
was me declaring the string 'lines' prior to the main body of the program. If I don't put it in there I get this error message:
[code]"The name `lines' does not exist in the current context (CS0103)"[/code]
in reference to the last line of code:
[code]foreach(string word in lines){ [/code]
You asked about this snippet:
[code]{
}[/code]
Well, I assumed that the argument "./wordscramble" would be 12 letters (not counting the ./). I also assumed that "args[1]" would refer to the second [i]element[/i] of the array "args" ie. the file name entered by the user. (Yeah, I know what happens when I assume!)
You also wrote:
[quote]mywordlist would then be stored in (args[0])[/quote]
So, the command "./wordscramble" isn't considered part of the "args" array? OK, I'll work with that, and see what happens.
Anyway, here is the full "WordScramble" code (note that I have a comment with the error message next to the line that MonoDevelop doesn't like):
[code]
using System; //created by Chris Adams 6/16/10
using System.Collections.Generic;
using System.IO;
namespace WordScramble
class MainClass
static List<string> WordList = new List<string>();
static List<string> UsedList = new List<string>();
static Random Rand = new Random();
static string PromptLetters;
if (args.Length > 0){
else{
foreach(string word in lines){ //Error Msg. -> Cannot convert type `char' to `string' (CS0030)
if (word.Length < 3) continue;
if (word.Contains("'")) continue;
WordList.Add(word.ToLower());
Console.WriteLine("");
Console.WriteLine("Welcome to WordScramble!");
Console.WriteLine("Type !quit to exit, !letters for a reminder, or !next for a new word.");
var score = 0;
GetLetters(); //goes to GetLetters subroutine
Console.WriteLine(PromptLetters);
bool running = true;
while (running){
string input = Console.ReadLine(); //get player input
switch (input){ //look for !quit, !next, !letters commands
case "!quit":
running = false;
break;
case "!next":
GetLetters();
Console.WriteLine("Score = " + score);
break;
case "!letters":
break;
default: //check to be sure word exists, & hasn't been used already
if (!UsedList.Contains(input)){
if (WordIsPossible(input)){
if (WordList.Contains(input)){
UsedList.Add(input);
var WordScore = WordValue(input);
score = score + WordScore;
Console.WriteLine("Good! Score = " + score);
} else {
Console.WriteLine("That word doesn't exist!");
} else {
Console.WriteLine("Did you forget your letters, or something?");
Console.WriteLine("Reminder: " + PromptLetters);
} else {
Console.WriteLine("You've used that word already!");
break;
static void GetLetters(){ //GetLetters subroutine
PromptLetters="";
UsedList.Clear();
string word = "";
while (word.Length < 8) {
word = WordList[ Rand.Next(WordList.Count) ];
foreach (char letter in word){
PromptLetters = PromptLetters + letter + " ";
static bool WordIsPossible (string word){
string letters = PromptLetters;
int pos = letters.IndexOf(letter);
if (pos != -1){
letters = letters.Remove(pos, 1);
}else{
return false;
return true;
static int WordValue(string input) {
var wvalue = 0;
foreach (char letter in input){
wvalue++;
return wvalue;
[/code]
Thanks for your time, Ram.
chriswadams
chriswadams
Postby Ram » Fri Jun 25, 2010 7:39 am
Hi Chris,
Your placement of a { was in the wrong place.
class MainClass
//static string lines; Not needed
} else {
        // } Brace is in the wrong place - it closes the else code block giving the lines error when called in the following foreach code block so need to go after it.
  } The brace goes here
Postby chriswadams » Tue Jun 29, 2010 11:30 pm
Ram -
You were right about the placement of the { . I moved it to the location you suggested and the error message disappeared. Thanks!
However, I still have a question about launching a program with arguments.
Code:
./wordscramble
Code:
So I changed my code from this:
to this:
string[] lines = File.ReadAllLines(args[0]);
but when I tried to launch the program with a single argument, I got this error message:
Unhandled Exception: System.IndexOutOfRangeException: Array index is out of range.
at WordScramble.MainClass.Main (System.String[] args) [0x00000]
If the 1st argument is held in "args[0]" then why is the index out of range?
Thanks again for your time,
chriswadams.
chriswadams
Postby Ram » Wed Jun 30, 2010 1:05 am
That because you have not told it what to do with with with the supplied file (args.Length > 0)
It reads
Then skips to
GetLetters();
And the error is coming from GetLetters() as the word array is empty.
I'll let you figure out what's missing :)
Postby chriswadams » Thu Jul 01, 2010 10:11 pm
Aha! :D What was missing was this code block:
The way I had it, if I started the program with one argument, the program skipped right over the above code. By copying and pasting it like so:
the error message disappears, and the program accepts arguments like it should. Eureka!
Thanks again for your time, Ram!
chriswadams
chriswadams
Postby Ram » Fri Jul 02, 2010 6:49 pm
Ready for project 3 now :)
Good luck.
