USB Pen Drives
USB Pen Drives
Postby Webwally » Tue Apr 19, 2005 10:29 am
I'm looking for some advice on USB pen drives. I'm running Mandrake 10.1, and want to be able to transfer movie/audio files from my Mandrake pc to my win xp machine. I have 2 CD Writers/Re-Writers in my Mandrake machine but I'm not sure how to go about transfering data onto the CD's. So, I thought about going with the USB Pen Drive (Linux Compatable). Any suggestions?
Thanks
Jason (Newbie to Linux)
Webwally
RE: USB Pen Drives
Postby towy71 » Tue Apr 19, 2005 10:52 am
just get yourself a pen drive and plug it in Mandrake and other distros will automagically :wink: put an icon on your desktop for the pen drive, then you just copy things across as you would between any device
HTH
Dick
RE: USB Pen Drives
Postby Guest » Tue Apr 19, 2005 11:57 am
Thanks yowy71 for a swift reply ;-)
Jason
RE: USB Pen Drives
Postby towy71 » Tue Apr 19, 2005 12:44 pm
yowy71 hm does that sound better or what? :wink: :lol:
RE: USB Pen Drives
Postby Guest » Tue Apr 19, 2005 2:48 pm
Sorry for the spelling mistake "towy71" LOL
Jason
RE: USB Pen Drives
Postby fingers99 » Tue Apr 19, 2005 5:39 pm
Try K3b: if you've ever used any CD burning software in the past, it's pretty simple. If not, there's the manual.
fingers99
Re: RE: USB Pen Drives
Postby gfhgfhfg » Sun May 15, 2005 3:34 pm
gfhgfhfg
Re: USB Pen Drives
Postby vcbb » Sun May 15, 2005 5:28 pm
vcbb
