How sloganizer changes the sig image each time it's reloaded
leke
PostPosted: Sun Apr 11, 2010 3:15 pm    Post subject: How sloganizer changes the sig image each time it's reloaded Reply with quote
A few of us are using sloganizer in our sig (check out mine)
I've just coded (ok just finishing) my own version which will change the image every time the page (a python script) is called. I can't figure out how sloganizer knows how to change the users slogan image each time it is requested in the sig?
Any ideas?
Thanks.
I codes here: http://notsure.tk
PostPosted: Mon Apr 12, 2010 4:02 am    Post subject: Reply with quote
Sloganizer uses a PHP script to connect to the Sloganizer server and write the slogan.
Code:
<?php readfile("http://www.sloganizer.net/en/outbound.php?slogan=Sloganizer"); ?>
PHP code is processed every time a page is sent from the server, just like these forums using phpBB.
leke
PostPosted: Mon Apr 12, 2010 6:39 pm    Post subject: Reply with quote
I'm not sure if I understand about what you said there, but that's ok, I'm pretty dumb.
The sig url in this forum is http://www.sloganizer.net/en/image,not-spc-sure,white,black.png which fetches the image. I been investigating though and I think those comma seperated strings are values passed to the script that looks like a .png image, but is in fact, a script (for example, php). I hear you can add something to the web server that passes whatever extension you want to run like it was a script. I guess you can return some kind of image stream back as the file request.
Some links about it:
http://www.scriptygoddess.com/archives/2004/10/19/gifs-that-execute-a-php-script/
http://stackoverflow.com/questions/198606/can-i-use-commas-in-a-url
The other thing I can think of is that it's just a cron job executing the script every 15secs or so Very Happy
PostPosted: Wed Apr 14, 2010 12:32 pm    Post subject: Reply with quote
OK, Sloganizer.net use a BBCode style URL to call the PNG image file:
Code:
[url=http://www.sloganizer.net/en/][img]http://www.sloganizer.net/en/image,Sloganizer,white,black.png[/img][/url]
On the Sloganizer.net server they just put a new PNG file every so often with a new slogan, or that URL calls a script on their server that generates a new PNG file that is sent back for each request. How often do the "slogans" change?
leke
PostPosted: Wed Apr 14, 2010 3:34 pm    Post subject: Reply with quote
Code:
Yep, I did some refreshing of the page and it looks like it changes every 30 secs or so. It would look like a cron job that uses values in the .png url.
The first part [url=http://www.sloganizer.net/en/] is not influenced by the script since I have it linked to my website instead.
