uber.munkee
Joined: Sun Jul 26, 2009 3:27 am Posts: 3 Location: The Sprawl
Posted: Mon Apr 05, 2010 4:15 pm Post subject: Coding Academy n00b |
Hi all,
I've tried a few times to really get stuck in to the Coding Academy projects but I can't get past the first one. I follow the tutorial to the letter but having never coded before I'm not sure what I'm doing wrong.
This is my code:
using System;
using System.IO;
namespace ToDoList
class MainClass
public static void Main (string[] args)
var contents = File.ReadAllText("todo.txt");
foreach (var arg in args) {
Console.WriteLine(arg);
This is as far as I get. If I try this on my own distro, when I press F8 it comes up with an error
Expected '}' (CS1513)
When I try it running the LiveCD and I press F8 I get
Parsing error(CS8025)
Would be grateful for any advice. |
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Mon Apr 05, 2010 4:51 pm Post subject: |
count the number of opening brackets and closing brackets, they always have to be in pairs  _________________ still looking for that door into summer |
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1569 Location: Guisborough
Posted: Mon Apr 05, 2010 9:20 pm Post subject: |
As towy say's { come in pairs
Try this code.
| Code: |
using System;
using System.IO;
namespace ToDoList
class MainClass
Normally, if you have a syntax error in your code when using MonoDevelop you'll have a red wriggly line under it. _________________
