Pyclutter and Gst
Pyclutter and Gst
Postby asmas » Fri Apr 02, 2010 7:52 am
Does anyone know how to install the python bindings for cluttergst in ubuntu? When I tried to import cluttergst it threw up an import error
asmas
Postby dhester » Mon Apr 19, 2010 12:19 am
Anybody? I have the same problem, what distro was used in the tutorial in the mag?
Could an iso be produced of a working system so that we can follow the examples in the mag, I really want to use the webcam example.
dhester
Postby Hudzilla » Thu Apr 29, 2010 12:55 pm
Hey!
I queried Nick on this; here's what he said:
The cluttergst module is usually included with the pyclutter - or at
least it was, up until the 0.92 (i think?) release. If you are using a
more recent Pyclutter, you will have to install it separately, or grab
the package from your repository.
The source is available here
http://clutter-project.org/sources/pycl ... 0.0.tar.gz
you just need to unpack the archive and do the usual ./configure &&
make && sudo make install
also which may be of use to you, there is now a repository for
clutter/open hand packages:
To use, add the relevent line for your distribution to
/etc/apt/sources.list and apt-get update.
deb http://debian.o-hand.com etch/
deb http://debian.o-hand.com unstable/
deb http://debian.o-hand.com edgy/
deb http://debian.o-hand.com feisty/
deb http://debian.o-hand.com gutsy/
deb http://debian.o-hand.com hardy/
it's definitely better to get them from here than to build them yourself.
Paul
Hudzilla
