Project 3 Chronojohn
Postby kurt » Thu Mar 25, 2010 12:31 pm
I finished up Project three with what appears to be with no problems. I can
issue : /bin/Debug$: ./Chronojohn.exe /home/kpas/Test and back up my files.
06:45 one.129139873560000000
06:59 one.129139883630000000
08:10 one.129139926160000000
06:45 three.129139873640000000
08:10 three.129139926050000000
06:45 two.129139873600000000
08:10 two.129139925870000000
However, when I run: /bin/Debug$ ./Chronojohn.exe list I get the output below.
Unhandled Exception: System.IO.DirectoryNotFoundException: Directory 'list' not found.
at System.IO.Directory.GetFileSystemEntries (System.String path, System.String searchPattern, FileAttributes mask, FileAttributes attrs) [0x00000]
at System.IO.Directory.GetFiles (System.String path, System.String searchPattern) [0x00000]
at System.IO.Directory.GetFiles (System.String path) [0x00000]
at Chronojohn.MainClass.CheckDirectory (System.String directory) [0x00000]
at Chronojohn.MainClass.Main (System.String[] args) [0x00000]
kpas@mars:~/Projects/Chronojohn/Chronojohn/bin/Debug$
When I run the following command I get nothing printed to the screen.
bin/Debug$ ./Chronojohn.exe list /home/kpas/Test
/bin/Debug$
/bin/Debug$ ./Chronojohn.exe list /home/kpas/Test/
/bin/Debug$
But I get the following output when I run ./Chronojohn
Chronojohn: a backup tool Kurt would have been pround of.
add /some/directory Scan directory and backup changed files
list /some/file List all backup of a given file
restore /some/file <ver> Restore file to specific version
I compared the CD version to what I did in mono but could not find any differences.
Any suggestions would greatly be appreciated.
Thanks,
Kurt
kurt
Postby sciso » Mon Jul 19, 2010 9:52 pm
Hey I'm stuck on Chronojohn myself but if your program is trying 2 backup the non existent /list directory id suggest the line
ListBackups(args[1]);
may be
ListBackups(args[0]);
in your program, that would be the hardest to spot kind of mistake for me anyway.
If not then gl ive got my own hair to replace
sciso
