branmask
Posted: Wed Mar 03, 2010 11:21 pm Post subject: Coding Academy - WordScramble Help |
Hello all,
I have the code done for wordscramble(not including the homework), but for some reason all it prints in the terminal is: You've had that word already!
Even when I know I've typed a good word. ie:
cassandre
case
read
I'm thinking something is out of place or incorrect in my code, but I can't seem to find it. If anyone can see where I went wrong, help would be appreciated. Thanks. Here's my code:
using System;
using System.Collections.Generic;
using System.IO;
namespace WordScramble
class MainClass
static List<string> WordList = new List<string>();
static List<string> UsedList = new List<string>();
static string PromptLetters;
static Random Rand=new Random();
public static void Main(string[] args)
string[]lines = File.ReadAllLines("wordlist");
foreach(string word in lines){
if(word.Length < 3) continue;
if(word.Contains("'"))continue;
WordList.Add(word.ToLower());
Console.WriteLine("");
Console.WriteLine("Welcome to WordScramble!");
Console.WriteLine("Type !quit to exit, !letters for a reminder, or !next for a new word.");
GetLetters();
Console.WriteLine(PromptLetters);
bool running = true;
while (running){
string input = Console.ReadLine();
switch (input){
case "!quit":
running=false;
break;
case "!next":
GetLetters();
break;
case "!letters":
break;
default:
if(UsedList.Contains(input)){
if(WordIsPossible(input)){
if(WordList.Contains(input)){
UsedList.Add(input);
Console.WriteLine("Good!");
}else{
Console.WriteLine("That word doesn't exist!");
}else{
Console.WriteLine("Did you forget your letters or something?");
Console.WriteLine("Reminder:"+PromptLetters);
}else{
Console.WriteLine("You've had that word already!");
break;
static void GetLetters(){
PromptLetters="";
UsedList.Clear();
string word ="";
while (word.Length < {
word = WordList[Rand.Next(WordList.Count)];
foreach (char letter in word){
PromptLetters = PromptLetters + letter +"";
static bool WordIsPossible(string word){
string letters = PromptLetters;
foreach(char letter in word){
int pos = letters.IndexOf(letter);
if (pos !=-1){
letters = letters.Remove(pos, 1);
}else{
return false;
return true;
branmask
Posted: Wed Mar 03, 2010 11:29 pm Post subject: |
nevermind! I figured it out. in the " if (!UsedList.Contains(input)){ " line I didn't put the "!" before UsedList.
Thanks anyways... |
