Which library? Or:what's in the libs?
Postby Dutch_Master » Sun Feb 14, 2010 5:34 pm
I'm trying to get to grips with C++ (with the Stroustrup book) and so far, so good. I understand the concept of linking to libraries for certain functions, but where can I find which library holds a particular function?
Pretty basic, I know, but if you wanna learn to cook, you gotta know what the ingredients do ;)
Postby Dutch_Master » Tue Feb 16, 2010 8:23 pm
Nobody? :cry:
Postby Bazza » Tue Feb 16, 2010 9:05 pm
Hi DM...
Not sure if this is what you want but........
Just Google the #include(s) in your program and there is
plenty of info...
For example...
#include <time.h>
Search for "time library c++" without the quotes...
If you want the functions in #include <stdio.h> then
search for "stdio library c++" without the quotes...
K&Rs C Programming Language is a very thorough look
at C and its derivatives and a lot of the standard libraries
although a little out of date in my copy...
Hope this helps...
73...
Team AMIGA...
Bazza
