USB help
USB help
Postby heiowge » Sat Feb 06, 2010 9:00 pm
This is part help, part other OS.
I'm at my mother's house and she can't use her new USB flash drive. It used to be mine, and it normally works just fine.
The problem is that XP (haven't converted her to desktop linux just yet) recognises it, but won't install it.
It gets part way through the plug n play setup then goes to the "found new hardware" wizard. This then fails to install, it says "the data is invalid".
I'm at the end of my tether trying to get it working.
Ideas please?
Postby MartyBartfast » Sat Feb 06, 2010 9:43 pm
I expect you've tried this but if it appears in Explorer then reformat it, not much good if there's something on it you want though :(
MartyBartfast
Postby Bazza » Sat Feb 06, 2010 9:49 pm
Try a complete power down for a few minutes and power up
again.
If it is a laptop etc, remove the battery for a few minutes
after powering down.
Sometimes all OSes get their knickers in a twist somewhere
along the line... :/
73...
Team AMIGA...
Bazza
Postby heiowge » Sat Feb 06, 2010 10:21 pm
Both no use I'm afraid (back home now on a sensible OS).
The problem has been ongoing for about 3 months, I've only just got to have a look at it. I think the driver is either missing or corrupted. I couldn't find a driver in microsoft.com for it, and online searches were fruitless.
I did find several programs that would scan for and replace missing / obsolete / damaged drivers (I'm not fussed if they install rubbish along the way since I'll probably have to reinstall the OS soon anyway - I just want to know if it's a hardware or software issue.) These programs turned out to be free to scan, but then demand money with menaces! You know the type - look at what's broken, now pay up or we won't fix them!
Attempts to get this software to function **ahem** totally legitimately without paying **ahem ahem** didn't pan out. :wink:
I don't want a patch. Just a USB 2.0 driver for XP.
Anyone have one?
Postby Bazza » Sat Feb 06, 2010 10:58 pm
Don`t quote me on this but I`m pretty sure a fully functioning
generic USB 2.0 driver was part of SP2.
I assume at least SP2 is installed?
73...
Team AMIGA...
Bazza
Postby heiowge » Sat Feb 06, 2010 11:59 pm
Yeah, and SP3. It's just broken. She used to have full USB 2.0, and her old flash drives work, but her new one and her new camcorder aren't recognised.
Postby ollie » Sun Feb 07, 2010 11:18 am
Try re-installing the motherboard drivers, it will probably be seen as a "downgrade" but don't let Windows "upgrade" to the Microsoft supplied hardware drivers.
HTH
Postby heiowge » Sun Feb 07, 2010 12:28 pm
How do I do that? It's not something I've tried before.
Postby Ram » Sun Feb 07, 2010 2:19 pm
Put the motherboard cd driver disk in the machine.
It should auto load ( if not browse to it)
Install the usb/chipset drivers.
Postby heiowge » Sun Feb 07, 2010 4:49 pm
... if she's still got it! :lol:
Postby paulm » Tue Feb 09, 2010 12:26 am
Umm... If the intent is to determine whether there is a hardware problem or whether it is just Windows being Windows, would not the simplest approach be to boot from a Linux live CD and try the USB stick from it?
Paul.
paulm
Postby heiowge » Tue Feb 09, 2010 8:50 am
...now why didn't I think of that! lol.
Postby LeeNukes » Tue Feb 09, 2010 10:19 pm
My three pence worth:
1) Try it in a different USB port (you've tried this right?)
2) Completely remove the USB devices from Device Manager in Windows, it should detect them and reinstall them from the driver cache on reboot. But make sure you have a Windows XP CD just incase it doesn't.
3) You could try a sfc /scannow from the run prompt. This will check the state of the Windows files and replace them if required. This normally needs the XP CD if there is an issues, also if there isn't most of the time.
LeeNukes
Postby heiowge » Tue Feb 09, 2010 10:41 pm
1) Tried. No joy.
2) She's actually lost the discs!:roll:
3) See point 2.
She's got a 64 bit machine and I've got a XP install disk for a 32 bit one. Can I pull it off that?
Maybe this is an opportunity to finally get linux on her desktop. It was a big step for the netbook, but maybe... just maybe...
Postby LeeNukes » Tue Feb 09, 2010 11:03 pm
64bit XP, that's probably the route cause in all honesty. I've had no end of issues in the past on 64bit XP machines, so much so we replaced it with a 32bit install at a customers in my previous job. They had a site license though, so it was "free".
I wouldn't bother with the 32bit CD if I were you, hurt and pain lies in that direction. At best it will just fail, at worst it will replace something critical by accident and you'll get blue screen after blue screen.
USB Guide:
http://www.usbman.com/WinME%20USB%20Guide.htm
This includes a link to the Microsoft USB Stick manager tool. You tried that?
More USB Windows XP SP3 help:
http://www.online-tech-tips.com/compute ... ecognized/
LeeNukes
