ToDoList - Programming Academy
Postby Cheemag » Sat Jan 23, 2010 3:22 pm
OK I've typed in the highlighted lines in the special edition booklet as
they appear. Is this supposed to compile: (?)
using System;
using System.IO;
var contents=File.ReadAllText("todo.txt");
contents=File.ReadAllText("someotherfile.txt");
contents="Hello World";
Console.WriteLine(File.ReadAllText("todo.txt"));
Gives:
2 Errors
! .. Line Description
Using the CD that came with the booklet, you could have warned users
that the keyboard wasn't set up!
Regards,
Cheemag.
Linux Mint-8 on a key-drive.
PCLinuxOS 2009-2.
Windows XP Home SP2
Cheemag
Postby Judda » Sat Jan 23, 2010 5:03 pm
Is that the complete program, as it's missing a lot of code & {}.
You should take a look at the code listing on the disk for the ToDoList.
Judda
Postby Cheemag » Sun Jan 24, 2010 12:00 pm
Judda wrote:Is that the complete program, as it's missing a lot of code & {}.
That's all the highlighted bits within the section "Reading from a File" to the end of that section. I assumed that you just string all the highlighted bits together and run the thing. (?)
I'll see if I can find it.
How do I switch off Mono's annoying and distracting suggestions system when trying to type code into the IDE?
Regards,
Cheemag.
PCLinuxOS 2009-2.
Windows XP Home SP2
Cheemag
Postby Judda » Sun Jan 24, 2010 5:30 pm
"How do I switch off Mono's annoying and distracting suggestions system when trying to type code into the IDE?"
I thought this is one of mono's greatest features.
If you read them, you'll learn quite a bit - well I do anyway.
To turn off: edit>preferences>text editor>general>untick "Enable code completion">OK
Judda
Postby Cheemag » Mon Jan 25, 2010 3:17 pm
Judda wrote:"How do I switch off Mono's annoying and distracting suggestions system when trying to type code into the IDE?"
Thank you.
Regards,
Cheemag.
PCLinuxOS 2009-2.
Windows XP Home SP2
Cheemag
