reCAPTCHA
reCAPTCHA
Postby bobthebob1234 » Wed Jan 20, 2010 6:32 pm
I would like to add a captcha to a form I have (which sends emails...) However it works in IE (6) but not firefox (on ubuntu & winblows)...
here is some code
 <form action="new.php" method="post" name="form">
<?php
require_once('recaptchalib.php');
$publickey = "(deleted)";
$privatekey = "(deleted) ";
# the response from reCAPTCHA
$resp = null;
# the error code from reCAPTCHA, if any
$error = null;
# are we submitting the page?
if ($_POST["submit"]) {
   $error_count=0;
   echo '
     <tr>
     <td colspan="2" class="errors">
   Checking
   </td>
  $resp = recaptcha_check_answer ($privatekey,
                                  $_SERVER["REMOTE_ADDR"],
                                  $_POST["recaptcha_challenge_field"],
                                  $_POST["recaptcha_response_field"]);
  if ($resp->is_valid) {
    echo "<tr><td colspan=\"2\" class=\"errors\">You got it!</td></tr>";
    # in a real application, you should send an email, create an account, etc
  } else {
    # set the error code so that we can display it. You could also use
    # die ("reCAPTCHA failed"), but using the error message is
    # more user friendly
    $error = $resp->error;
   $error_count++;
    echo '<tr><td colspan="2" class="errors">The captcha was incorrect. ' . $error . '</td></tr>';
  if ($error_count > 0) {
      $s ="";
      if ($error_count > 1) {
         $s = "s";
       echo "<tr><td colspan=\"2\" class=\"errors\">There was $error_count error$s. Please correct these and try again.</td></tr>";
and
<fieldset><legend>Captcha</legend>
Please enter the two words below.
<?php
echo recaptcha_get_html($publickey);
      </fieldset>
If i echo $_POST["recaptcha_challenge_field"], in firefox it is blank and in ie it has lots of random letters and hashs,etc
Any ideas why this would be, and how to fix it?
Thanks
bobthebob1234
Postby Dutch_Master » Wed Jan 20, 2010 7:10 pm
phpBB3 has a working Cotcha environment, why not 'nick' their code? ;)
Postby ollie » Thu Jan 21, 2010 10:18 am
Dutch_Master wrote:phpBB3 has a working Cotcha environment, why not 'nick' their code? ;)
reCAPTCHA supply the code required for free - no need to "nick" the code because it is free.
I haven't had any problems with reCATCHA, I've just included the code at http://recaptcha.net/plugins/php/. Point "3" goes at the top of your page. You make the page containing the form a PHP page and the code at point "4" goes on your form processing page (also PHP).
Note: I have deleted the public and private keys from your code posting, you don't want to give the private one out :wink:
Postby bobthebob1234 » Thu Jan 21, 2010 6:22 pm
opps thanks.
I'll try coping and pasting that code (again...) (although i did use the example first...)
bobthebob1234
Postby Dutch_Master » Thu Jan 21, 2010 6:26 pm
ollie wrote:reCAPTCHA supply the code required for free - no need to "nick" the code because it is free.
Which is why I put it in ' marks :P
Postby bobthebob1234 » Thu Jan 21, 2010 6:41 pm
Something else in the page must be breaking it. Have tried new code and still not work. However copied example code to new page it all is good.
I also regenerated the keys.
bobthebob1234
Postby bobthebob1234 » Thu Jan 21, 2010 7:05 pm
I think it doesn't like tables in tables. Got it to work now (for the moment!). Thanks to all.
bobthebob1234
