Coding Academy - Fell at first hurdle!
Cheemag
PostPosted: Tue Jan 19, 2010 6:16 pm    Post subject: Coding Academy - Fell at first hurdle! Reply with quote
Hello,
Surprised( I didn't get past the first fence with the ToDoList project in Linux Mint:
/ There is always one thing to remember: \
| writers are always selling somebody |
| out. |
| -- Joan Didion, "Slouching Towards |
\ Bethlehem" /
\ ,__,
\ (oo)____
(__) )\
mint@mint ~ $ cd/ToDoList/ToDoList/bin/Debug
bash: cd/ToDoList/ToDoList/bin/Debug: No such file or directory
mint@mint ~ $
I had no better luck in PCLinuxOS:
[jim@localhost ~]$ cd ToDoList/ToDoList/bin/Debug
bash: cd: ToDoList/ToDoList/bin/Debug: No such file or directory
[jim@localhost ~]$
Also (2nd page, 1st column) There's no "Run" option in the Project menu. Run is a menu in its own right.
Same column under "Reading from a file", it wasn't clear that
"goto Applications>Accessories>Terminal" wasn't a option in Mono, but a system option. Didn't help me tho'
Regards,
Cheemag.
Linux Mint-8 on a key-drive.
PCLinuxOS 2009-2.
Windows XP Home SP2
PostPosted: Tue Jan 19, 2010 7:33 pm    Post subject: Reply with quote
Have a look at this thread.
As for the location of the Run command, it used to be in the Project Menu prior to MonoDevelop 2.
Cheemag
PostPosted: Wed Jan 20, 2010 11:37 am    Post subject: Reply with quote
Doesn't help. I expect that directory location was meant to be used in the programming environment run from the cover CD rather than with Mono installed on a system.
I'll do a file search.
OK, thanks.
Regards,
Cheemag.
PCLinuxOS 2009-2.
Windows XP Home SP2
PostPosted: Wed Jan 20, 2010 12:06 pm    Post subject: Reply with quote
OK then, the easy way to find where the file is store is:
Open your todolist project in MonoDevlop
Goto menu Project
Select Option
Click General in the left hand pane.
Look to the bottom right Location, this where your files are.
cd into the Debug folder from the above location
Cheemag
PostPosted: Wed Jan 20, 2010 5:17 pm    Post subject: Reply with quote
Goto menu Project
Select Option
Thanks. I'll go and have a look.
Regards,
Cheemag.
PCLinuxOS 2009-2.
Windows XP Home SP2
random_excess23
PostPosted: Sat Feb 06, 2010 1:28 am    Post subject: Reply with quote
Hi Cheemag
There appears to be a misprint in the magazine, try typing:
cd Projects/ToDoList/ToDoList/bin/Debug
PostPosted: Sat Feb 06, 2010 2:37 am    Post subject: Reply with quote
random_excess23 wrote:
Hi Cheemag
That's not the directory, he's using his own distro of Mint, not running it from the cdrom.
Cheemag
PostPosted: Sat Feb 06, 2010 11:37 am    Post subject: Reply with quote
Hi Cheemag
PCLinuxOS acutally.
I've put this aside for the moment. I hope to come back to it soon.
I wish they had chosen something other than C#, perhaps Python? I've always hated C !!
Regards,
Cheemag.
PCLinuxOS 2009-2.
Windows XP Home SP2
cncman
PostPosted: Fri Apr 02, 2010 4:03 am    Post subject: Reply with quote
I'm using PCLinuxOS 2009.2
worked for me.
However,
Quote:
./ToDoList.exe hello from mono
gives me
Quote:
bash: ./ToDoList.exe: cannot execute binary file
I just got my Coding Academy kit tonight & haven't had time to try it on the Ubuntu DVD yet.
The only thing smart about me is... I know where to find the answers.
PostPosted: Fri Apr 02, 2010 10:29 am    Post subject: Reply with quote
cncman try running it like this
mono ToDoList.exe hello from mono
cncman
PostPosted: Fri Apr 02, 2010 5:21 pm    Post subject: Reply with quote
Hey Ram,
I'll give it a try.
I did get the Codding Academy DVD up and running and, naturally, the command from the magazine does work there.
So, Understanding the the DVD is specially configured for the purpose of codding... What changes would I need to make to my Distro to allow it to work for the same purpose?
cncman
PostPosted: Mon Apr 05, 2010 5:15 pm    Post subject: Reply with quote
I just wanted to confirm that running the commands like this does work in PCLinuxOS2009.2.
