C++, new, delete, constructors & Qt
Biscuiteer
PostPosted: Mon Jan 18, 2010 4:49 pm    Post subject: C++, new, delete, constructors & Qt Reply with quote
Hello all,
I've recently returned to C++ after a break of a few years and would like a few points clarifying about new and delete, as used in class constructors / destructors.
I understand that every single thing created using new, must be explicitly deleted before the program quits. Correct?
Following Qt's built in Address Book tutorials (as sadly all the tuxradar ones fail with segmentation faults) I note that even though the class constructor in question uses new to create dynamic objects, the destructor is left empty. Ok, that might be down to stripping down the code for the purposes of education but when I add delete commands to the destructor for each instance of new in the constructor, I run into trouble. See the annotations in the code.
Code:
AddressBook::AddressBook(QWidget *parent)
    : QWidget(parent)
    QLabel *nameLabel = new QLabel(tr("Name"));
    nameLine = new QLineEdit; // nameLine declared as (private) pointer in class header file
    QLabel *addressLabel = new QLabel(tr("Address"));
    addressText = new QTextEdit; // addressText declared as (private) pointer in class header file
    QGridLayout *mainLayout = new QGridLayout;
    mainLayout->addWidget(nameLabel,0,0);
    mainLayout->addWidget(nameLine,0,1);
    mainLayout->addWidget(addressLabel,1,0, Qt::AlignTop);
    mainLayout->addWidget(addressText,1,1);
    setLayout(mainLayout);
    setWindowTitle(tr("Simple Address Book"));
AddressBook::~AddressBook()
//    delete nameLabel;     // <-- Compiler error: Out of scope
    delete nameLine;     // declared as private pointer in class header file
//    delete addressLabel;     // <-- Compiler error: Out of scope
    delete addressText;     // declared as private pointer in class header file
//    delete mainLayout;     // <-- Compiler error: Out of scope
Is there a memory leak if delete is not called for these objects, and if so, how to delete the ones that are declared out of scope in the destructor?
thanks
R
1slipperyfish
Forum Jester
PostPosted: Mon Jan 18, 2010 5:31 pm    Post subject: Reply with quote
hello i'm no c++ expert but should it not be
Code:
    delete nameLine[];     // declared as private pointer in class header file
    delete addressText[];     // declared as private pointer in class header file
//    delete mainLayout[];     // <-- Compiler error: Out of scope
if that doesn't do it post so and i'll have fiddle but i learned it as [] , but you have to free all memory you use for every constructor you must have a de-constructor,
i was using this as reference but someone who is better than me might know different ?or if you could post the rest of the code? Very Happy
hth Very Happy
paul
PostPosted: Mon Jan 18, 2010 5:33 pm    Post subject: Reply with quote
Wouldn't calling a destructor as
Code:
~addressText();
work?
Biscuiteer
PostPosted: Mon Jan 18, 2010 6:44 pm    Post subject: Reply with quote
1slipperyfish (troll): no that doesn't work. I don't use delete[] as I'm not trying to delete arrays.
Ram: Would I be correct to say that I shouldn't have to call class destructors, they should automatically be called?
My problem is one of scope, I think. Why does this work?
Code:
// class definition (addressbook.h) exerpt:
#include <QtGui/QLineEdit>
class AddressBook : public QWidget
private:
    QLineEdit *nameLine;
//class methods exerpt:
#include "addressbook.h"
    : QWidget(parent)
    nameLine->setReadOnly(true);
    delete nameLine;
And why does the following not work
Code:
#include <QtGui/QLabel>
    : QWidget(parent)
    delete nameLabel;
is it purely because nameLine is declared in the class definition and nameLabel isn't?
spaceyhase
PostPosted: Mon Jan 18, 2010 7:51 pm    Post subject: Reply with quote
Yes, because 'nameLabel' only exists within the scope of the constructor (between the braces Wink ). The example doesn't feature 'nameLabel' though, are you adding it yourself? However, one thing to note here is that the 'ui' object has 'ownership' of these objects when they're constructed; it's counter-intuitive in a way but because 'ui' is deleted by the constructor, it will clean up the remaining objects for you Smile
Biscuiteer
PostPosted: Mon Jan 18, 2010 9:02 pm    Post subject: Reply with quote
spaceyhase - thank you! That makes sense now. I'm not adding 'nameLabel' myself, it appears in the version of the tutorial that's built into Qt Creator's help. I think that this is the same version here too.
Not quite sure what you mean about the 'ui' object though, do you mean the QWidget class that the AddressBook class is derived from? And quite what is it cleaning up automatically?
PostPosted: Mon Jan 18, 2010 10:19 pm    Post subject: Reply with quote
Quote:
We construct a new AddressBook widget on the stack and invoke its show() function to display it. However, the widget will not be shown until the application's event loop is started. We start the event loop by calling the application's exec() function; the result returned by this function is used as the return value from the main() function. At this point, it becomes apparent why we instanciated AddressBook on the stack: It will now go out of scope. Therefore, AddressBook and all its child widgets will be deleted, thus preventing memory leaks.
That's the last part of Part 1 - Does that help..
PS. thanks for the link to 4.6 - I.ve got 4.5 install and only the first 4 part of this tutorial are there.
Biscuiteer
PostPosted: Tue Jan 19, 2010 2:56 pm    Post subject: Reply with quote
Yes, that helps! Somehow I missed reading that the first time around,
thanks everyone,
R
