Buster
Posted: Sat Jan 02, 2010 7:18 pm Post subject: Stuck at the First Hurdle! |
Hi All
I have never programmed before and decided to have a crack at C# on Monodevelop using the LXF coding academy tutorials on tuxradar. Unfortunately I have got stuck half way through the first one
This is my code:
| Code: |
using System;
using System.IO;
namespace ToDoList
class MainClass
public static void Main(string[] args)
if (args[0] == "add") {
File.AppendAllText("todo.txt", args[1] + "\n");
} else {
var contents = File.ReadAllText("todo.txt");
Console.WriteLine(contents);
And this is the error I get:
| Code: |
Unhandled Exception: System.IndexOutOfRangeException: Array index is out of range.
at ToDoList.MainClass.Main (System.String[] args) [0x00000] in /home/stu/Projects/ToDoList/ToDoList/Main.cs:16
This error occurs when I run "./ToDo.exe" without parameters. When I run it with something like ./ToDo.exe add "This is a test" it works fine.
If I understand the error correctly it is telling me that the array is not initialising properly from this line (I think):
| Code: |
Having gone over my code several times, and spending a long time googling the issue I have got no further on.
Can anyone please explain to me where (and why) I have gone wrong so that I can owrk out how to get it right.
Cheers
Buster _________________ My Computer Once Beat Me at Chess, but it is No Match for Me at Kickboxing! |
Buster
Posted: Sat Jan 02, 2010 10:03 pm Post subject: |
It's okay, I've finally worked out what is going wrong!
I haven't completed enough of the code to deal with no parameters at all being entered so when I run:
it causes the error because these lines:
| Code: |
are basically saying "if the first parameter equals 'add' then write 'parameter 2' to the file todo.txt".
Therefore when I run it with no parameters at all I get the error because the first part of the code (argument?) fails meaning that the second part cannot complete because it depends on part 1.
If I run it with a first parameter of anything but 'add', for instance:
the program correctly displays the contents of todo.txt as it should.
If anyone has the time to confirm that I have understood this correctly it would be appreciated.
Bazza LXF regular
Joined: Sat Mar 21, 2009 11:16 am Posts: 1381 Location: Loughborough
Posted: Sat Jan 02, 2010 11:30 pm Post subject: |
Well done that man...
If this is your first programming experience and you`ve
solved it yourself then you will easily get to grips with
programming in general...
In your codes` case...
args[x] are the "arguments" that follow the executable command.
Computer definition or arguments:-
(From the WWW.)
`In programming, a value that is passed between programs,
subroutines or functions. Arguments are independent items,
or variables, that contain data or codes. When an argument
is used to customize a program for a user, it is typically
called a "parameter."`
For example...
"MyCommand My name is Bazza" has four arguments,
args[0] == My
args[1] == name
args[2] == is
args[3] == Bazza
"MyCommand" by itself has NO arguments hence, (in your case),
your ORIGINAL error.
SO........
Judging by your code it requires two arguments
ToDoList add sometext<RETURN/ENTER>
"add" is the first argument args[0] that sets the condition
for the "if" statement.
AND
Assuming "todo.txt" exists "sometext" along with a "newline"
character will be added to the end of the file.
Note: I suspect "sometext" is not critical as args[1] becomes
a NULL, (no character in this case), and only a "newline" will
be added BUT "add", args[0], must be included for it to do
this...
that`s the best way I can describe it...
And finally your conclusion was basically correct.
Welcome to the fascination world of programming... :) _________________ 73...
Team AMIGA... |
Buster
Posted: Sun Jan 03, 2010 9:47 pm Post subject: |
Bazza
Thanks for the comprehensive explanation, it is really appreciated
Your response raised another question for me though:
| Quote: |
this...
I can see what you are saying here; and it makes perfect sense however that is not what is happening in practice and I wondered if you (or anyone else) could perhaps explain why?
I have clipped some code output below so that you can see what is going on:
| Code: |
stu@xps-laptop:~/Projects/ToDoList/ToDoList/bin/Debug$ ./ToDoList.exe add Test
stu@xps-laptop:~/Projects/ToDoList/ToDoList/bin/Debug$ cat todo.txt
Test
stu@xps-laptop:~/Projects/ToDoList/ToDoList/bin/Debug$ ./ToDoList.exe add "This is a test"
Test
This is a test
Test
This is a test
The source code remains as previously posted.
It's not hugely important, I'm just curious that's all.
Thanks again
Ram LXF regular
Joined: Thu Apr 07, 2005 10:44 pm Posts: 1549 Location: Guisborough
Posted: Mon Jan 04, 2010 12:12 am Post subject: |
| Quote: | ./ToDoList.exe add
at ToDoList.MainClass.Main (System.String[] args) [0x00000] |
You have not passed a second argument (args[1]) but the following code is expecting it.
The array currently only holds one element (argument) so crashes trying to read the second element.
| Code: |
using System;
using System.IO;
namespace ToDoList
class MainClass
} else {
An array is a group or set of things
args[] is the array in the above code.
colours[red,green,orange,purple] is an array of 4 colours.
Arrays usually index (count) from zero.
colours[0] = red
colours[1] = green
colours[2] = orange
colours[3] = purple
| Code: |
Console.WriteLine("The first colour is ", colours[0] + "\n" );
That would just print out The first colour is red
| Code: |
Console.WriteLine("The fifth colour is ", colours[4] + "\n" );
Would error with a Index out of range as there is no 5th element. _________________
Buster
Posted: Mon Jan 04, 2010 8:53 am Post subject: |
Got it, thanks very much
