heiowge LXF regular
Joined: Wed Feb 27, 2008 8:21 pm Posts: 1803 Location: Cheshire, UK
Posted: Mon Sep 28, 2009 11:41 pm Post subject: Replacing Windows without disturbing Linux |
Ok, I'm sure it's possible. Is it easy though?
Can I replace XP on my XP / Ubuntu 9.04 dual boot with Windows 7 without major damage to my Ubuntu setup.
I can reinstall ubuntu but i'd rather not. I've only just got it back to the way I like it after the last reinstall! |
ollie Moderator
heiowge LXF regular
Posted: Fri Oct 02, 2009 10:04 pm Post subject: |
followed instructions. setup (hd0) failed.
rebooted and no grub. went straight to win7.
ideas? |
nelz Moderator
Posted: Sat Oct 03, 2009 12:22 am Post subject: |
| heiowge wrote: | followed instructions. setup (hd0) failed.
ideas? |
One idea would be to tell us the output from setup (hd0), then we might be able to do more than guess why it may have failed. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
ollie Moderator
Posted: Sat Oct 03, 2009 5:56 am Post subject: |
| heiowge wrote: | | rebooted and no grub. went straight to win7 |
Well, you definitely didn't overwrite the MBR  |
heiowge LXF regular
Posted: Sat Oct 03, 2009 8:29 am Post subject: |
Thankyou for that!
I have managed to get it back up and running, but had to reinstall and set up compiz, ubuntu tweak and god knows what else. I just wish that the discs had a "reinstall grub menu after windows install" option. Maybe a request for a new option for the cover discs?
Bearing in mind just how many linux users have dual boot systems with windows and that a lot of them will be installing Win7 atm, wouldn't it be nice to show just how easy it is to repair the damage windows does? |
towy71 Moderator
Joined: Wed Apr 06, 2005 3:11 pm Posts: 4176 Location: wild West Wales
Posted: Sat Oct 03, 2009 8:50 am Post subject: |
This topic has been covered many times! A quick google comes up with loads of help forum threads the best of which is here
heiowge you can expect a severe telling off from nelz for doing a re-install rather than fixing the problem  _________________ still looking for that door into summer |
heiowge LXF regular
Posted: Sat Oct 03, 2009 10:25 am Post subject: |
Actually, I didn't do a reinstall. Sorta. I followed loads of different advice sets, none of which worked as advertised.
The last one said to reinstall, but not use the format option. How was I supposed to know that it'd remove some software! The guide (off ubuntu forums, which had lots of people saying how well it worked) seemed like a good method.
And yes. First thing I did was search round forums, starting with this one.  |
nelz Moderator
Posted: Sat Oct 03, 2009 10:27 pm Post subject: |
That's worse than a reinstall. Repeat100 times, Linux is not Windows. _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
heiowge LXF regular
Posted: Sat Oct 03, 2009 10:39 pm Post subject: |
I'm not entirely sure how that helps me though!  |
nelz Moderator
Posted: Mon Oct 05, 2009 10:08 am Post subject: |
You'll learn  _________________ "Insanity: doing the same thing over and over again and expecting different results." (Albert Einstein) |
ollie Moderator
Posted: Mon Oct 05, 2009 11:06 am Post subject: |
| nelz wrote: | You'll learn  |
... and that's important. |
