syncrosoft
Posted: Wed Aug 12, 2009 12:24 pm Post subject: Syncro Soft Announces New Release of Syncro SVN Client |
Syncro Soft Ltd, the producer of Syncro SVN Client, has announced the immediate availability of version 5.0 of its Subversion (SVN) client.
Version 5.0 of Syncro SVN Client adds the Diff Files and Diff Directories tools, updates the main menu and toolbar actions for the Working Copy, Synchronize and Repository views, and comes with a new application toolbar for easy access to the most common SVN operations.
For the complete list of features please visit http://www.syncrosvnclient.com
New in version 5.0:
Diff Files tool allows finding the differences between two files with other algorithms than the built-in one of the SVN server and applying some options like ignore whitespaces, merge adjacent differences, etc.
Diff Directories tool allows finding the differences between two sets of files that have the same names but are located in different folders. Two files with the same name can be compared with the binary content method or the last modification timestamp method.
The menus and toolbars were changed. Some actions where added or removed in the menu bar and in the Working Copy, Synchronize, Repository, History views so that the most used actions can be accessed faster. A new toolbar was added.
For compatibility with applications that may not support the latest working copy format, this can be specified at checkout: SVN 1.4, SVN 1.5 or SVN 1.6.
Upgrade/Downgrade actions for changing the working copy format, allowing to maintain compatibility with applications that do not support the latest working copy format.
Pricing and Availability
Syncro SVN Client with One Year Maintenance Pack costs $59
Syncro SVN Client Site License with One Year Maintenance Pack costs $2970
Volume discount rates are available starting with 5 licenses.
Syncro SVN Client can be run on Windows, Mac OS X, Linux, Solaris.
To purchase please visit the Syncro SVN Client store at
http://www.syncrosvnclient.com/buy.html
Syncro SVN Client 5 can be freely evaluated for 30 days from
http://www.syncrosvnclient.com/download.html
About Syncro Soft LTD
Syncro Soft is a privately held software company founded in 1998 with a large area of expertise in XML technologies: XML Schema, Relax NG, Schematron, XSLT, XPath and XQuery. The main product oXygen XML Editor provides the best coverage of the today XML technologies; it complies with the established standards released by W3C and other organizations and enhances developer productivity through an intuitive and innovative XML IDE. Syncro Soft is a member of W3C.
oXygen is a registered trademark of Syncro Soft in the U.S and other countries. Subversion is a trademark of CollabNet. Any other trademarks or service marks contained herein are the property of their respective owners.
SOURCE: Syncro Soft Ltd.
support@syncrosvnclient.com
http://www.syncrosvnclient.com/ |
