Newbie needs help
Newbie needs help
Postby juniper » Wed Aug 31, 2005 12:33 pm
Hello to all you Linuxers!
Well, I finally made the dip into the Linux world by purchasing the Linux Format Special edition mag "Get started with Mandriva Linux".
I have just installed Mandriva and after a few hair raising moments it installed fine. Except......
I get an error message at start up from the Soundserver - The KDE Crash Handler:
Short Description
The application Soundserver (artsd) crashed and caused the Signal 11 (SIGSEGV).
The backtrace is as follows
(no debugging symbols found)
Using host libthread_db library "/lib/tls/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1218132288 (LWP 6819)]
0xffffe410 in ?? ()
#0 0xffffe410 in ?? ()
#1 0xb7601000 in ?? ()
#2 0x00000000 in ?? ()
#3 0x00000000 in ?? ()
#4 0xb7983303 in __waitpid_nocancel () from /lib/tls/libpthread.so.0
#5 0x08053e85 in ?? ()
#6 0x00001ac0 in ?? ()
#7 0x00000000 in ?? ()
#8 0x00000000 in ?? ()
#9 0x08071440 in ?? ()
#10 0x00001aa3 in ?? ()
#11 0x08073428 in ?? ()
#12 0x08072c8c in ?? ()
#13 0xb7862ff4 in ?? () from /lib/tls/libc.so.6
#14 0x00000400 in ?? ()
#15 0x00000400 in ?? ()
#16 0xbfffec98 in ?? ()
#17 0x00000000 in ?? ()
#18 0xb7864800 in __malloc_initialize_hook () from /lib/tls/libc.so.6
#19 0x080dbd70 in ?? ()
#20 0xb7959e74 in ?? () from /usr/lib/libstdc++.so.6
#21 0xb7862ff4 in ?? () from /lib/tls/libc.so.6
#22 0xb7864800 in __malloc_initialize_hook () from /lib/tls/libc.so.6
#23 0x080db4d0 in ?? ()
#24 0xbfffecb8 in ?? ()
#25 0xb779f37a in free () from /lib/tls/libc.so.6
I am a total newbie to Linux and have very little understanding of what this message means. I have just played an original CD using KsCD with no problems but when I try to load Amarok I get an error message stating that the artsd service could be loaded.
Can anyone advise?
Thanx in advance.
juniper
RE: Newbie needs help
Postby A-Wing » Wed Aug 31, 2005 1:11 pm
This usually happens to artsd when a library is missing or damaged. Did you get any errors or warnings while installing?
Andrew Hutchings, Linux Jedi
http://www.a-wing.co.uk
A-Wing
Postby juniper » Wed Aug 31, 2005 2:17 pm
No I did not. The only problems I had was that the installation did not follow the path as described in the magazine when it came to the partitioning the the Hard Drive. I did not get the filesystem types windows displayed - but other than that things went OK.
However, I have followed the instructions in the magazine for the updates CD but it fails to load it. It reports media errors:
Unable to add medium, errors reported.
Unable to retrieve pathname.
I am following the advice in the magazine but cannot make sense of this.
juniper
Re: RE: Newbie needs help
Postby Marrea » Wed Aug 31, 2005 2:33 pm
juniper wrote:I am following the advice in the magazine but cannot make sense of this.
I couldn't make sense of the instructions about adding the updates CD either. If you do exactly as set out in the magazine, you do indeed get an error message. I think something has been left out of the instructions.
I eventually got the CD to add by fiddling around. I seem to remember that after clicking on Add custom and ticking Removable device and browsing for Path or mount point, I had the cdrom listed in the left hand column. I then double-clicked on cdrom and clicked on Add, which added "main-updates 13/07/05" in the right hand column. I had no idea what I was supposed to put in "Name" so I put Main Updates CD4(cdrom4) and for "Path or mount point" /mnt/cdrom/main_updates was already entered. I selected All packages, by update availability, Upgradeable. This installed 95 packages from CD4. There was nothing listed under Addable.
Sorry if this is not very clear, either - but I can't remember now exactly what I did.
Marrea
RE: Re: RE: Newbie needs help
Postby juniper » Wed Aug 31, 2005 3:25 pm
I think I have installed them although I would not put money on it. Thank you for your input.
In the Add Custom window I gave the direct path to the files - it was not enough to point it to the cdrom, I had to point it directly to the files on the cdrom.
However, this still has not resolved my original problem.
juniper
